Dividing project into modules in deamon directory
is it possible to divide project in deamon directory and then require("./script1") like in NodeJS?
Done is better than perfect
You can either place libraries/code parts in store/libs directory, then you can load them the via:
require('applibs.mylib') -- custom.mylib for older versions
Or you can place them together with daemon but then you will need to specify full path. Use this short wrapper function:
function loadlib(path)   return dofile('/data/apps/store/daemon/' .. path .. '.lua') end loadlib('myapp/mylib')
ThanksWink
