Threads: 57
Hi.
I just tested the LoRa communication between two devices. I set up the two devices with same LoRa parameters and the same encrytion key. I then disconnected the CAN connector from one of the devices, and guess what... The two devices continued communication over wireless automatically!! This is fantastic!
Kai-Roger
Threads: 9
I have the UIO8(8 universal IO ports +loRa) and R4 (4 Relay outputs + LoRa), I did the same but when i disconnected the CAN connector in the R4 the trasmit light in UIO8 lights up and the receive Light in the R4 lights up at the same time but nothing happends, the relay isn´t activating :/
Threads: 9
16.08.2019, 15:32
(This post was last modified: 16.08.2019, 15:45 by HannPark.)
I just uploaded the last firmware to my devices,
r4-lora_20190701.dfu
uio8-lora_20190701.dfu
And update my CANx App on LM, and I used the same loRa config from the video guide, using as a gateway the UIO8 and the R4 in Device Mode, but the problem persist... It work over CAN but when I disconnect the CAN wire on the R4, it stop working, but the orange light labeled as "T" in UIO8 lights up... and in the R4 a blue one turns on at the same time...
Thanks for ur support...
Threads: 32
Hello
I have same problem , i did update last firmwear on canx devices and canx apk. I have comunication with cable but when remove one device from network does not work with lora
Thanks in advance.
Threads: 31
Threads: 21
In the can lora system,How can I program or change programs for can-lora devices that are not connected to the can bus through LM (can)?Can anyone help me?
Thanks in advance.
For security reasons parameters can only be changed via wired CAN connection but not over radio.
Threads: 21
In practical use, devices controlled solely through LORA communication must be connected to the can bus to complete program configuration before installation,right?
Yes, all configuration is done via wired CANx bus connection.
