CanX and LoRa
Hi.
I just tested the LoRa communication between two devices. I set up the two devices with same LoRa parameters and the same encrytion key. I then disconnected the CAN connector from one of the devices, and guess what... The two devices continued communication over wireless automatically!! This is fantastic!
Kai-Roger
1 x CAN-UI8-LoRa
(15.04.2019, 21:20)Kai-Roger Wrote: Hi.
Kai-Roger
Hello Kai,
Great ! Good news !
B.R,
Chouaibou.
I have the UIO8(8 universal IO ports +loRa) and R4 (4 Relay outputs + LoRa), I did the same but when i disconnected the CAN connector in the R4 the trasmit light in UIO8 lights up and the receive Light in the R4 lights up at the same time but nothing happends, the relay isn´t activating :/
Hi there,
please make sure to upgrade the CANx devices to the latest firmware:
http://dl.openrb.com/canx/
Follow this guide and install the software from here (at the bottom of the page):
https://openrb.com/canx-technology/
Then upgrade CANx app on LogicMachine.
Then try reconfigure following this guide:
I just uploaded the last firmware to my devices,
r4-lora_20190701.dfu
uio8-lora_20190701.dfu
And update my CANx App on LM, and I used the same loRa config from the video guide, using as a gateway the UIO8 and the R4 in Device Mode, but the problem persist... It work over CAN but when I disconnect the CAN wire on the R4, it stop working, but the orange light labeled as "T" in UIO8 lights up... and in the R4 a blue one turns on at the same time...
Thanks for ur support...
Hello
I have same problem , i did update last firmwear on canx devices and canx apk. I have comunication with cable but when remove one device from network does not work with lora
Thanks in advance.
Try using these firmwares: http://dl.openrb.com/canx-new/
Make sure that all LoRa devices are using updated fws. And perform reset on all devices by holding programming button for 5 seconds. Release the button once red LED starts flashing.
(16.08.2019, 15:32)HannPark Wrote: Γεια σας,
θα ήθελα απλώς ανεβάσει το τελευταίο firmware για τις συσκευές μου,
R4-lora_20190701.dfu
Και ενημερώσετε canx App μου για LM, και χρησιμοποίησα το ίδιο Lora ρυθμίσεων από τον οδηγό βίντεο, χρησιμοποιώντας ως πύλη η UIO8 και το R4 στο Device Mode, αλλά το πρόβλημα παραμένει ... Δουλεύει πάνω από CAN αλλά όταν αποσυνδέω το καλώδιο CAN στο R4, σταματά να λειτουργεί, αλλά το πορτοκαλί φως που φέρει την ένδειξη "T" στο UIO8 ανάβει ... και σε το R4 ένα μπλε ενεργοποιεί την ίδια στιγμή ...
Ευχαριστώ για την υποστήριξη ur ...
(03.04.2020, 06:33)admin Wrote: Δοκιμάστε να χρησιμοποιήσετε αυτά τα firmware: http://dl.openrb.com/canx-new/
Βεβαιωθείτε ότι όλες οι συσκευές LoRa χρησιμοποιούν ενημέρωση fws. Και πραγματοποιήστε επαναφορά σε όλες τις συσκευές κρατώντας το πλήκτρο προγραμματισμού για 5 δευτερόλεπτα. Αφήστε το κουμπί μόλις αρχίσει να αναβοσβήνει το κόκκινο LED.
Hi admin
i did update and work the lora , but the uio8 does not work inputs and outputs i loaded this firmwear (uio8-lora_20200319)
Thanks in advance
Try this firmware
http://dl.openrb.com/canx-new/uio8-lora_20200406-2.dfu
Works well for me.
(06.04.2020, 12:26)Daniel. Wrote: Hi
Try this firmware
Works well for me.
Yes it work!!!
