Schedule on/off
How can i make a button on my visualization that turn a spesific schedule on and off?
Hi.
You can use this script to get your function.
-- Enables / Disables schedulers
name = 'Scheduler 1'
active = event.getvalue()
db:update('schedulers', { active = toboolean(active) }, { name = name })
clearschedulers()
--------------end---------------------
--------------put this in common functions---------------------
function clearschedulers()
  local files = io.ls('/tmp')
  for _, file in ipairs(files) do
    if file:find('lm-scheduler-', 1, true) then
      os.remove('/tmp/' .. file)
---------------------end-------------------------------------------
Thanks for your reply, I'm new to this scripting so where do i need to change the script to make it fit my Schedule name?
Change Scheduler 1 to your name.
(02.05.2019, 05:39)Rauschentofft Wrote: Change Scheduler 1 to your name.
Thanks, it works!  Smile
