TCP Socket Connection for Legrand
#21
Thank you very much, now it looks much more hopeful. But is there still a problem?
Increase socket timeout by changing sock:settimeout(1) to sock:settimeout(5)
Thank you administrator!
So already in the alarms the connection is ok.
How do I see the messages from the bus in LM? Because at the moment I only have * # * 1 ##, but not what's going on online. My goal is to transfer all lamps and thermostats to LM for easier and more beautiful operation. That is, I need to be able to read and change their condition.
I apologize for the stupid questions, but I'm still new to writing scripts.
After the connection is open you need to call read and parse the incoming data. For sending commands a separate script might be needed because there are two session types - command (*99*0##) and event (*99*1##). Unfortunately it's quite hard to make a full example without being able to test it on a real device.
Okay, I get it.
I used the sample TCP code:
function read(sock)
  local buf = {}
  while true do
    local ch, err = sock:receive(1)
    if ch then
      local pr = buf[ #buf ]
      buf[ #buf + 1 ] = ch
      if ch == '#' and pr == '#' then
        break
      return nil, err
  local ret = table.concat(buf)
  log(ret)
  return ret
-- init socket
if not sock then
  require('socket')
  sock, err = socket.connect('192.168.1.247', 20000)
  -- set timeout to 1 second
  if sock then
    sock:settimeout(1)
  -- error opening connection, log error and wait before reconnecting
    error(err)
    sleep(5)
-- socket handler
if sock then
sock:send('*99*1##')
--data = sock:receive(14)
   res, err = read(sock)
--sock:send('*#1*12##')
-- log('check')
-- sock:send('*1*1*12##')
  -- got data, log it
  if data then
    log(data)
 and I'm currently getting this:
* # 4 * 1 * 0 * 0229 ## in log.
Which means that the temperature of thermostat 1 is 22.9 degrees. How to separate the digit with the code 1 to be address 32/1/1 and write the value 22.9 in it? How do I separate receiving and sending commands so that it works properly?
Hi, I made several attempts to control the MX200 with a script, but unfortunately failed. I have the following commands on the line:
MH200
26.04.2022 19:53:58
* string: *1*9*11##    90%
MH200
26.04.2022 19:54:15
* string: *1*1000#0*11##    OK
MH200
26.04.2022 19:54:15
* string: *1*0*11##    OFF
could you help me to bind them in a script so that I can recognize them on arrival and bind them to the respective objects and accordingly if the value of the object changes I send the command back to the gateway?
This is the code I use to get them in the log:
function read(sock)
  local buf = {}
  while true do
    if ch then
        break
      return nil, err
  log(ret)
  return ret
-- init socket
if not sock then
  require('socket')
  if sock then
    sock:settimeout(1)
    error(err)
    sleep(5)
-- socket handler
if sock then
  if data then
    log(data)
Use this. Changing mapping will require full script restart via disable/enable.
if not sock then
  mapping = {
    ['11'] = '1/1/11',
  function parselighting(what, where)
    local addr = mapping[ where ]
    what = tonumber(what) or -1
    if addr and 0 <= what and what <= 10 then
      grp.checkwrite(addr, what * 10)
  function parse(msg)
    local who, what, where = unpack(msg:split('*'))
    who = tonumber(who)
    -- lighting
    if who == 1 then
  function read(sock)
    local buf = {}
    while true do
      if ch then
          break
        return nil, err
    if #buf > 0 and buf[ 1 ] == '*' then
      return table.concat(buf, '', 2, #buf - 2)
  sock = require('socket').tcp()
  sock:settimeout(1)
  res, err = sock:connect('192.168.1.247', 20000)
  if res then
    log('connect failed', err)
    sock:close()
    sock = nil
    os.sleep(1)
-- socket handler
if sock then
  if res then
    parse(res)
  elseif err == 'closed' then
    sock:close()
    sock = nil
This example partially implements parsing of lighting type messages (off and dimming).
Docs for all types: https://developer.legrand.com/documentat...or-myhome/
Thank you so much!
 It works perfectly, but now how can I send commands to the gateway when changing the object in a logic machine?
