13.05.2019, 09:09
Could anybody suggest doorlock with open API which I can integrate with smarthome system?
Figerprint doorlock integration
13.05.2019, 09:09
13.05.2019, 14:40
If you have KNX, I have used eKey in combination with Assa Abloy locks successfully. Works like a dream.
Sent from my iPhone using Tapatalk
27.11.2019, 14:47
Nuki is a doorlock with open API.
27.11.2019, 14:48
Abus Wapploxx
16.04.2020, 11:27
(13.05.2019, 14:40)mjaanes Wrote: If you have KNX, I have used eKey in combination with Assa Abloy locks successfully. Works like a dream. Hello! how do you integrate Assa Abloy locks with Logich Machine? I have to do a similar integration with the "TESA Smartair SOAP API". Can you help me please? Thanks!
16.04.2020, 14:49
There is an Logic Machine app for Ekey thsat of course also can be used with the Wiser for KNX or spaceLYnk.
https://forum.logicmachine.net/showthrea...light=ekey
17.04.2020, 08:23
(16.04.2020, 11:27)pentadom Wrote:(13.05.2019, 14:40)mjaanes Wrote: If you have KNX, I have used eKey in combination with Assa Abloy locks successfully. Works like a dream. I have the eKey KNX gateway installed. Sends a GA to the KNX bus upon reading a particular fingerprint successfully. I then (via LM or similar) just use a KNX actuator to send Voltage to the lock (same way as eKey). Hope this is helpful. Sent from my iPhone using Tapatalk
17.04.2020, 08:55
(17.04.2020, 08:23)mjaanes Wrote:(16.04.2020, 11:27)pentadom Wrote:(13.05.2019, 14:40)mjaanes Wrote: If you have KNX, I have used eKey in combination with Assa Abloy locks successfully. Works like a dream. And what about Assa Abloy locks? I'm really interested on it
14.10.2020, 05:36
Many different types of Assa Abloy locks out there. Mine (the EL482) has a built-in solenoid. Sending a 12v pulse to this will open the lock. 12v is provided via a KNX actuator triggered by a GA sent from either the LM or the eKey GW directly.
10.05.2021, 14:39
(27.11.2019, 14:47)Joep Wrote: Nuki is a doorlock with open API. Hi do you have a library for communication to Nuki? The API seems to be complex and having already done and tested library at the begining would be helpful.
10.05.2021, 15:49
(10.05.2021, 14:39)Thomas Wrote:(27.11.2019, 14:47)Joep Wrote: Nuki is a doorlock with open API. I'm at the same boat. I'm trying to integrate my Nuki bridge + Nuki keylock but seems quite difficult with the documentation I have found...
Is there any progress regarding integration with Nuki? Has anyone succeeded?
https://developer.nuki.io/ https://nuki.io/
05.07.2021, 06:48
Nuki has a bridge device which can be connected to LM via HTTP requests: https://developer.nuki.io/page/nuki-brid...api-1-12/4
06.07.2021, 08:37
(05.07.2021, 06:48)admin Wrote: Nuki has a bridge device which can be connected to LM via HTTP requests: https://developer.nuki.io/page/nuki-brid...api-1-12/4 Cool! I'm just going to try it with mine. Thank you! |
« Next Oldest | Next Newest »
