05.06.2019, 03:44
		Yesterday, my client give me the feedback that function OFF isn't now working. This function works in Resident 0s and its switch off near all lights in home and delays switch off of the lights on stairs. And script was halted, its status was "green" but this was a day so if it will be switched on at day it starts, do simple job and immediately disable itself so it was not working. I've found similar issue on other LM a few times but it was connected with HTTP or calculating statuses and small CPU power of devices. At this time this occured on LM5 with 20180523 firmware. I think it should be for sure solved, at least distinguish if some script is halted.
This is a script (if during day it immediatelly should switch of):
-- Gdy noc, wtedy wyłącz całe oświetlenie wewn. oprócz korytarza i schodów, które wyłącz z opóźnieniem (od wywołania lub ostatniego ruchu w strefie dziennej).
-- Gdy dzień, wtedy całe oświetlenie wewn.
if not disableScript then
  -- wstępna konfiguracja
  disableScript = function()
    grp.checkupdate("OFF_signalling", false)
    script.disable(_SCRIPTNAME)
  grp.checkupdate("OFF_signalling", true)
  grp.write("OFF_Natychmiast", false)
  grp.write("OFF_Później", not day) -- jeśli noc wtedy włącz oświetlenie orientacyjne m.in. schody
offset = grp.getvalue("OFF_Czas świecenia")
day = grp.getvalue("Dzień")
if day then
  disableScript()
    return
waitFromLastMotion = grp.getvalue("OFF_odliczaj od ruchu")
if waitFromLastMotion then
  local motionInDayZone = grp.find("Ruch w strefie dziennej_status")
  local lastMotion = motionInDayZone.updatetime
  local motion = motionInDayZone.value
  local elapsed = os.time() - lastMotion
  if not motion and elapsed >= offset then
      -- wyłącz oświetlenie korytarza
    grp.write("OFF_Później", false)
    disableScript()
  elseif motion then
    os.sleep(offset + 1)
    -- odczekaj tyle co pozostało do 45
    os.sleep(offset - elapsed + 1)
  os.sleep(offset)
  disableScript()
Done is better than perfect
