Threads: 1
Hi all, I am fairly new in scripting using lua but I am quite experienced in other programming languages. I find it hard to determine how I can trigger an event after pressing down a button. I see that events are triggered after release of the button which means, event is triggered on Rising Edge of the button data. Can any body tell me if what I intend to do is possible?
Thank you in advance for your help.
Depends on how your button is configured. Most physical button inputs have rising (on) and falling (off) edge detection. You can set a fixed value to both actions, so in your script you can use event.getvalue() to figure out if button is pressed or released.
Threads: 8
Hi Sniper,
Currently there is only 1 event (on release) in spaceLYnk, i discussed this with the
DEV team to add a extra event in future FW. This way we could use long/short press etcetera.
As far as i know it's not implemented yet (and also not confirmed that it will be added)
but it could be possible with Javascript in new FW. I didn't try to create this but i think
we could create your wanted feature with it.
I hope (just like you) we have 2 events on button in one of the upcomming FW version..
Erwin van der Zwart
