Threads: 87
I have been using the Mosaic and the cloud. Works great.
But i need it with more hierarchy. So i must go back to the touch visu.
But then i have the problem with remote access. What could be the easiest solutution for remote access?
Company site so guess i rely on business`s it department aswell.
Use VPN. It's much more secure than port forwarding.
Threads: 32
I have a problem with the connection to the LM application ouside of my home with VPN.
So far I've had an iphone and I haven't had any problems but I see that the version of the android app is more recent and I have the following problem:
When I connect to the local network, it connects correctly but when I connect from outside, with VPN, the connection does not appear in "Home". I tried to put Http: // in front of the IP and it appears but it gives me the following error: "net :: ERR_UNKNOWN_URL_SCHEME"
What I can do?
Greetings
Threads: 30
with VPN can you go to visu via browser?
Threads: 30
Paste the url here. You shouldn't be adding http on front as it does it already.
While on VPN can you discover your LM?
Threads: 30
What if you try just this?
http://192.168.2.205/scada-vis or 192.168.2.205/scada-vis
Here is old app you can try it too
https://we.tl/b-m2ozs2A3Jo
Threads: 32
It work with 192.168.2.205/scada-vis
Thanks!!
