Access to the objects from script
I have a problem in scripts. In a script in GA Browser I have an access only to less than 2/0/21 and e.g. I can't search group address 4/0/11 by this tool.
Perhaps someone met with a similar problem?
Did you try the refresh button above the object pull down box? Did you try to refresh/reload browser?
If that still didn't work, you can try clearing cache (should not be needed)
You are using firefox so should be fine, you might try another browser (Like Chrome) to see if the problem is the same ..
Erwin van der Zwart
Can you send your backup to our support by e-mail? How many objects do you have in total?
(15.02.2016, 07:11)admin Wrote: Can you send your backup to our support by e-mail? How many objects do you have in total?
Yes, I can send a backup file. I have near 1625 objects(65pagesx25objects/page) now.
I will send a backup to info@openrb.com
