Threads: 98
Hi there,
I would like to customize the visu of 1 bit object (0 = Auto ; 1 = manual). But in Touch Visualisation (smartphone) I can choose visualisation in checkbox or toggle.
I would like show and manage manual or auto written.
What do you suggest please?
Threads: 98
Thank you Daniel,
only to be sure.
The modify about JS is done in additional classes field of the icon of 32/1/1.
Instead modify of CSS is done is Custom CSS of vis.graphic tab. Is it?
If so it does not work.
Threads: 30
JS is under Scripting ->Tools -> Custom Java Script
PS
Threads: 30
To see any result you have to open end visualization not editor and Add additional class 'custom' to the button on visu
Threads: 30
Additional class 'custom' is missing
Threads: 30
In the Visu editor
Threads: 47
Note that this will only work in Touch visualization, not in the editor.
Threads: 98
ooooooooooooook!! Thanks.
Everything is clear now. Custom is the name given to the btn.
Now I have created different name so I can link the any object I want.
I thank you very much for your support.
Regards.
Threads: 47
No problem, keep in mind that you need different additional class for each group addresses if you have several buttons like this.
