Solax X3 modbus profile
here is the modbus profile for Solax X3 (it should work with other models too).
It's based on info got from https://github.com/InfernoEmbedded/Power...xModbus.py
and other got by reverse engineering input registers.
No way to get holding registers information that could be useful to remotely control to inverter
No help by Solax.
Hope it helps.
Luca
.json   Solax X3 eng.json (Size: 7.45 KB / Downloads: 88)
(27.07.2019, 16:40)lpala Wrote: Hi,
No help by Solax.
Hope it helps.
Luca
Hi, please post this in this topic https://forum.logicmachine.net/showthread.php?tid=839
the entire protocol list in the attachment :-)
How to read the value under address 0x00A8 and 0x00A9 (0x04:Read Input Register)?
Thank you
In profile above is similar register defined 'Energy consumed' Just change correct address. Always use Read test to get correct parameter. I would use float32 for bus_datatype not float16 like here.
Thank you, I will test
