Threads: 39
how to use the APP DALI when password is different than the defaut admin?
For example, my DALI/KNX interface is set with different password
SE ECO EXPERT
Threads: 39
no idea ?
SE ECO EXPERT
Threads: 31
You should contact SE for this.
I don't have this gateway to check but I'm quite sure it doesn't need password to your DALI gateway. There is nearly no security on this DALI gateway.
Threads: 39
(20.08.2019, 12:45)Daniel. Wrote: You should contact SE for this.
ok
there is security acess. Defaut is admin/admin, but you can change it for increased Web access security. When using defaut, the App work, when I change it, doesn't work anymore.
SE ECO EXPERT
