Storage tab
I think it would be useful when there is an additional tab which shows which variables have been saved to storage.  Maybe allow them to be edited.  Literally like the objects tab.  At present when I am developing a script that stores something to storage,  I would have to write the stored variable to the log.  Although its quite workable to do it this way,  it is time consuming.
Thanks,
Roger
+1 here too
+2 here Smile
This can be implemented as a separate App. A version where you can only view storage variables is very easy to do. We can help a little bit if somebody is up to do it Wink
(29.02.2016, 09:32)admin Wrote: This can be implemented as a separate App. A version where you can only view storage variables is very easy to do. We can help a little bit if somebody is up to do it Wink
no problem, i can give it a try.. where to start, i have the sample app up and running? Smile
where to find more information / more sample apps?
I see only a sample widget, but some info is missing about:
- how to add a icon a startpage
- how to add lua code to the html file to get the storage vars
Sample Storage viewer app attached.
Follow this guide on how to upload it to your LM:
http://forum.logicmachine.net/showthread.php?tid=180
.zip   storage.zip (Size: 8.56 KB / Downloads: 34)
(02.03.2016, 08:14)admin Wrote: Sample Storage viewer app attached.
great... thanks.
It worksWink If you can, it will be perfect if there will be some ability to edit this variables, but it is very good improvement also nowWink
Maybe any idea why this example is very slow at loading from the mainmenu (more then 1 minute for 20 storage items)?
-In safari (ios) its slow every time
-In google chrome (windows) only the first load time
When i call http://myLM4/apps/data/storage/ directly, its not slow.
It is a known bug in beta FW that you are using, already fixed in current version.
Is it possible to execute code on the server, like storage.delete('abc'), when a button/link is clicked.
Something like: <a href="javascript:alert(\''+item[ 0 ]+'\')">delete</a>
(02.03.2016, 15:30)gjniewenhuijse Wrote: Is it possible to execute code on the server, like storage.delete('abc'), when a button/link is clicked.
UP
Patience Smile
I'll update the example next week.
(11.03.2016, 08:04)admin Wrote: Patience Smile
thanks Big Grin
Sorry for the delay, example updated with delete feature.
.zip   storage.zip (Size: 8.97 KB / Downloads: 39)
(05.04.2016, 12:10)admin Wrote: Sorry for the delay, example updated with delete feature.
Very good function. Thanks adminWink
You can now install this app directly from our store if you are running the latest FW Wink
where do i find the app store ?
Go to the main page, click user icon, provide admin password then click plus icon in the top right corner. There you can manage and install new apps. Assuming you are running latest firmware of course Smile
