how to check if holiday
Is it possible to check if the current date is a holiday? (as saved in the holidays tab)
There's no function to check this directly at this moment. You can create a scheduler with two events. Set first to run only on holidays and the second not to run on holidays.
I would make a bit object with a scheduler attached to it, set it to ""run only on holidays" and add a event at 0:00 to value 'true' and add a event to 23:59 to value "false"
Now the bit objects tells you that it is a holiday..
Thanks for the help..
