29.02.2016, 08:52
(This post was last modified: 29.02.2016, 09:07 by zoltan.
Edit Reason: Translated comments
I have a couple of this exact script running (8). The total number of scripts is around 60, but most are one or two liners, no timers, wait, delay etc.
All of them are working except this one, the script is enabled and the group address is of the correct data type.
What can I do to clear the problem?
System: CPU/IO: 0.52 0.58 0.57, Memory: 10%, KNX/TP: OK, error log is empty.
--SPV_act='15/5/3' -- ovdje salje vrijednost SPV
--SPV_dan='SPV_TEST_dan' -- varijabla u koju se sprema dnevni SPV
--SPV_noc='SPV_TEST_noc' -- varijabla u koju se sprema nocni SPV
--Vremenski_enabled_var='Vremenski_TEST_enable' -- da li je vremenski program omogucen
--Dan_Noc='SPV_TEST_dan_noc' -- podatak da li je aktivan dnevni ili nocni SPV
value = event.getvalue()
SPV_act='1/3/1' -- SPV active value sending
SPV_dan='SPV_hodnik_kat1_dan' -- SPV day
SPV_noc='SPV_hodnik_kat1_noc' -- SPV night
Vremenski_enabled_var='Vremenski_hodnik_kat1_enable' -- Is time scheduler enabled?
Dan_Noc='SPV_hodnik_kat1_dan_noc' -- Is day or night SPV selected
storage.set(Dan_Noc,value)
enable_vremenski = storage.get(Vremenski_enabled_var)
if (enable_vremenski == true) then
if (value == true) then
my_data = storage.get(SPV_dan)
grp.write(SPV_act, my_data)
if (value == false) then
my_data = storage.get(SPV_noc)
if (enable_vremenski == false) then
