Threads: 1
30.03.2020, 15:44
(This post was last modified: 30.03.2020, 15:53 by robert.ranga.)
i have a Logic Machine LM5 Power Lite with version: 20200116, at one of my client.
And i have another one with the 20191015 - this one i want to upgrade.
It is possible?
Why i can't download the 20200116 version?
Thank you!
Threads: 43
You can keep using 20191015 as there's no big difference between 20200116 and 20191015 apart from some minor bug fixes. Not all firmware versions are published.
Threads: 7
as downgrade are not possible, did you know when final 2019 firmware will be released ?
(or at least an RC2 ?)
Best regards
Threads: 43
No exact date at the moment, probably by the end of summer due to the current situation. We've decided to add some minor features and improvements to the new firmware. Why do you want to downgrade? RC1 is pretty stable, no major bugs were reported.
Threads: 7
10.04.2020, 16:09
(This post was last modified: 10.04.2020, 16:11 by olivier.)
ok thank you, so I will use it
the upgrade process check the compatibility of the firmware with the logic machine ?
No risk to install the wrong firmware ?
Best regards
Threads: 7
I think it's much easier if we add a column showing the plan ID in the vis structure tabs (:
Threads: 43
Ok, plan/widget ID will be added.
