Time function for object selected by final user
i need advice from expert.
Easy part:
I have to do a clock to change Setpoint temperature on several Thermostat.
Hard part:
However the customer has 200 different thermostat in the building. He want that the clock event (time program of LM) send value only on thermostat he selected before.
For information, every thermostat are on separate widget.
I would like to do two generic press buton that take the widget name and add a tag to the setpoint thermostat group adress like "clock1" and "clock2".
Easy part:
Then on the clock1 event, only send to the group addresse taged "clock1" for example
Then on the clock2 event, only send to the group addresse taged "clock2" for example
Hard part:
When open again the widget, the checkbox should be checked if the tag is "clock1"
If you have other idea. First I was thinking of creating all thermostat setpoint group adress in other group adress range and use it as checkbox, but lots of work, and would like to know if there is not smarter way.
Maybe using Variable storage in DB
and script like this but for widget:
$(function(){
  var previousPlanId = 0;
  $(document).on('vclick click', function() {
    writecurrentpage();
  function writecurrentpage(){
    if ( currentPlanId == 1 && currentPlanId != previousPlanId ) {
      grp.write('1/1/1', currentPlanId);
      previousPlanId = currentPlanId;
SE ECO EXPERT
