Threads: 32
Is there any way to change circular slider widget to vertical slider in touch visu?
I want it to do that for shutter controll.
Threads: 35
Why don't you use Mosaic instead? It has widget like that.
Threads: 35
How did you come to this assumption? Both use exactly the same websocket.
Vertical slider is not implemented in Touch mode at this moment. Either use standard or circular slider.
