ekey fsx App
The new "ekey fsx" App is available for download at the Appstore:
This application can be used
- to integrate ekey FSX scanners into the LogicMachine environment as KNX sensors (to monitor fingerprints / RFID cards / binary inputs) or as KNX actuators (to control scanner's on-board relay and scanner's LED lights)
- to act as functional alternative to traditional biometric ekey access control solution 'ekey net' or 'ekey home' with multiple extra functions:
       - attached ekey scanners can be configured, operated and monitored online using this app
       - can be registered max. 200 fingerprints
       - can connect up to 8  ekey fingerprint scanners to a single LogicMachine RS485 port or to a ekey USB converter;
       - can hold internal user credentials (fingerprints and RFID cards) in a database;
       - can use LogicMachine lua scripts for functions not included into web application user interface.
The last actual v. 20201108 App user manual can be downloaded :
http://www.ekey.lv/logicmachine/ekey-app/ekey-app-20201108-manual.pdf
The ekey FSX fingerprint scanners should be registered with a Access code to enable full functionality of the App.
* Please note, the "Access code" price is extra 40 Eur for each ekey FSX scanner!
My company also sell the ekey FSX scanners for the same price value as an equivalent ekey home type scanner from ekey-shop.com.
In this case the Access code price is included in the ordered scanner price.
The registered forum.logicmachine.net users can order scanners with discount (see attached price list).
Agris
11.11.2020
ekey FSX App v.2020108 is released
The new installation package is now available in the LogicMachine App store and
can be downloaded: - http://www.ekey.lv/logicmachine/ekey-app...201108.ipk
Changes from previous v.20200711:
- The user can now register up to 3 RFID cards.
- Fields for RFID cards in the User records are hidden if there are no active scanners with an RFID option
- Enrollment function is extended with an interactive modal window and the feedback with a positive or negative enrollment result.
   + the fingerprint enroll, delete  functions are temporally blocked until the concurent enrollment process is finished (because of credentials synchronization limitations between scanners)
- New function to delete the selected log records.
- New function to Save (or export) the selected log records information into csv  (* or xls) file
   + to save the records to the xls file there is available external procedure to install / remove the luaxlswriter and its related packages (not available for LM2,LM3, LM4)
- New external function to update the scanner firmware to v. 06180115
20.07.2020:
The new "ekey FSX" app version available for download:
http://www.ekey.lv/logicmachine/ekey-app/ekey-app-20200711.ipk
The new separate "ekey TA" app with a simple “Time attendance” functionality
http://www.ekey.lv/logicmachine/ekey-app...200711.ipk
The user manual for both apps :
http://www.ekey.lv/logicmachine/ekey-app...manual.pdf
20.04.2020:
New release candidate ekey FSX app version available for dowload:
http://ekey.lv/logicmachine/ekey-app/ekey-app-20200416-rc.ipk
21.01.2020:
The new ekey FSX app version 20200120 is available for download.
http://www.ekey.lv/logicmachine/ekey-app...200120.ipk
Changes from previous v.20191202:
- new entry point for admin user (In the tab "Scanners": extra <Start>, <Stop> daemon commands)
http://192.168.0.10/apps/data/ekey/index_admin.lp
- serial communication stability improvements
- resolved: after new app installation automatically not found the active RS485 serial port
- resolved: the uncorrect "access error: Possible manipulation of access ...  "  event
- new service commands for scanner fingerprints managment:
      1) Clean the scanner fingerprint/RFID memory:
      2) Copy the fingerprints from the internal database to selected scanner
      3) Copy the fingerprints from the selected scanner to internal database
23.12.2019:
Known errors v.20191202:
1.  After new ekey fsx app installation not automatically found the serial port to which scanners are connected.
The correct RS485 port alternatively can be assigned manually with LM Lua script, using this pattern:
              storage.set("app:ekey:port", '/dev/RS485-2')
02.12.2019: The ekey FSX app version 20191202 is available for download.
User manual: http://www.avu.lv/logicmachine/ekey-app/...manual.pdf
.pdf   ekey FSX prices Y2019.pdf (Size: 268.46 KB / Downloads: 68)
.pdf   ekey FSX prices Y2020.pdf (Size: 199.1 KB / Downloads: 70)
This is a really nice app for the Ekey finger scanners that Agris made.
We used it for a couple of projects already and have to say that it is working very well.
So we can recommend this app in combination with the FSX scanners of Ekey.
http://ekey.lv/logicmachine/ekey-app/eke...416-rc.ipk
New functionality:
1. In the app is added a new tab "Attendance"
2. For User and Scanner records ir added new checkbox "is Time attendance" (TA)
3. the logic to register new TA event:
- The Scanner and the User must be enabled for TA event (User . TA = ' enabled' and Scanner.TA = ' enabled' )
- Time attendance event for every User has 2 directions: registration 'IN' or 'OUT'
registration event 'IN' happens when last attendance record is registered as OUT or not exist, and registration 'OUT' happens when last attendance record is registered as 'IN' .
The scanner after successful registration will show the attendance event direction with short LED lights
- for IN event, the scanner left LED will shortly will show the green colour 0.5s impuls
- for OUT event, the scanner right LED will shortly will show the red colour 0.5s impuls
There is implemented one automatic OUT event Time correction = to its corresponding ' IN ' Event Time , if after the OUT event in time period for the same User in period 1 min is recorder next IN Event. In this case the OUT record has specific "clock" icon in the field "Event time" .
http://www.ekey.lv/logicmachine/ekey-app/ekey-app-20200711-manual.pdf
New functionality:
1. New filter field "Period" is added to tab "Logs"
2. the tab "Attendance" is transfred to the new "ekey TA" app
The installation package is now available in the LogicMachine App store and
User manual: http://www.ekey.lv/logicmachine/ekey-app...manual.pdf
Thanks to Stefan Künstler from ekey biometric systems for this video:
https://www.youtube.com/watch?v=ty_2nP_mHHk
Information about the last actual ekey FSX scanner firmware v.06190506:
The main extra feature of this version is the future to enroll a wide scope of the RFID Mifare cards for scanners with the RFID function:
Now as RFID cards can be used bank cards, public transport cards, and for example the swedish ID06 person identity card for employees https://id06.se/english/
Steps to perform the scanner firmware update:
1) The ekey FSX app v.20201108 must be installed
2) you need to download the firmware file using lua script:
list = io.readproc ('wget -O /home/apps/store/user/ekey/update06190506.eku www.ekey.lv/logicmachine/firmware/update06190506.eku')
log(list)
3) and after execute the update separate for each scanner with the cmd :
http://192.168.0.10/apps/data/ekey/api.l...re=6190506
The result of FW update command you can see in the ekey fsx app log list.
4) After the FW update please restart the LM device!
