Threads: 72
Have a look here:
https://www.twilio.com/help/faq/twilio-b...-change-it
id_nr is your Account SID and token_nr is your Auth Token
Threads: 72
(02.03.2016, 12:29)admin Wrote: Have a look here:
thank admin so much!
" from_nr" and "to_nr" , what it?
thank all!
from_nr is Twilio number that is sending the message, in your Twilio account click "Get your first Twilio Number"
to_nr is the phone number that should receive the message
Threads: 0
11.10.2019, 05:06
(This post was last modified: 23.10.2019, 06:20 by cuong.nguyen@vis.solutions.)
I try to sent SMS by Twilio in VietNam as link:
https://openrb.com/notification-sms-from...desyntax_2
But, it's not working. I used this code for event:
from_nr = '+19177461563' -- Twilio phone number
to_nr = '+84932414151' -- My phone number
id_nr = '...' -- ACCOUNT SID
token_nr = '...' -- AUTH TOKEN
sms(id_nr, token_nr, to_nr, from_nr, 'Test SMS by SL'..tostring(value))
You have swapped from/to fields. It should be:
Code: sms(id_nr, token_nr, from_nr, to_nr, 'Test SMS by SL'..tostring(value))
Threads: 0
15.10.2019, 01:24
(This post was last modified: 15.10.2019, 01:25 by cuong.nguyen@vis.solutions.)
(11.10.2019, 06:52)admin Wrote: You have swapped from/to fields. It should be:
Same trouble
My Common Funtions:
Code: --SMS by Twilio
function sms(id, token, from, to, body)
local escape = require('socket.url').escape
local request = require('ssl.https').request
local url = string.format('https://%s:%s@api.twilio.com/2010-04-01/Accounts/%s/Messages.json', id, token, id)
local body = string.format('From=%s&To=%s&Body=%s', escape(from), escape(to), escape(body))
return request(url, body)
My Event:
Code: value = event.getvalue()
from_nr = '+19177461563' -- put sender SIM nr here
to_nr = '+84938354162' -- put recepient SIM nr here
id_nr = '...' -- put your ID here
token_nr = '...' -- put your token here
Replace sms function with this one:
Code: function sms(id, token, from, to, body)
local resp = {}
local stat, code, hdrs = request({
method = 'POST',
url = url,
protocol = 'tlsv12',
sink = ltn12.sink.table(resp),
source = ltn12.source.string(body),
headers = {
['content-length'] = #body,
['content-type'] = 'application/x-www-form-urlencoded'
if stat then
stat = table.concat(resp)
return stat, code, hdrs
Threads: 0
(15.10.2019, 13:53)admin Wrote: Replace sms function with this one:
local resp = {}
method = 'POST',
url = url,
headers = {
if stat then
It's working!! Thank you so much
But it takes about 15 min for 1 SMS, too long
You can try contacting Twilio support or ask your local operators if they provide SMS gateway service.
Threads: 0
(16.10.2019, 10:38)admin Wrote: You can try contacting Twilio support or ask your local operators if they provide SMS gateway service.
Hi, I tried to send command with https with this code:
Code: local http = require('ssl.https')
mime = require("mime")
res, err = ssl.https.request('https://api.speedsms.vn/index.php/sms/send?access-token=...&to=84938354162&content=hello')
log(res, err)
Log message:
Code: * arg: 1
* nil
* arg: 2
* string: Try again
I can send this link from web browser. But, not working with LM5. Please check and tell me how to fix this?
Try updating LuaSocket library (System config > System > Packages > Add (+) green button)
New CPU: https://dl.openrb.com/pkg/luasocket_2.0....9_imx6.ipk
Old CPU: https://dl.openrb.com/pkg/luasocket_2.0....09_mxs.ipk
Threads: 0
(18.10.2019, 12:36)admin Wrote: Try updating LuaSocket library (System config > System > Packages > Add (+) green button)
It's work on LM5. How's about the HL&SL? I don't see update packages function in System page
Threads: 0
(21.10.2019, 09:21)admin Wrote: Install latest firmware
I upgraded to ver 2.4.0. Still same trouble
Threads: 0
29.10.2019, 01:51
(This post was last modified: 29.10.2019, 02:52 by cuong.nguyen@vis.solutions.)
How can I fix this trouble?? W4K and LM5 can work, SL can not
Threads: 35
SL is using all the same libraries as W4K as long you use the same version of FW. If it doesn't work your problem is elsewhere.
Check that your device has correct gateway and DNS set in System config > Network > Interfaces
