Threads: 8
Hello ... how can I set a remote control so that it switches a lamp on and off.
I have an Eltako FTTB.
Press once to turn on the light.
and pressing again should turn the light off.
THX
Threads: 31
Hi, I didn't fully catch your question but this device use this profile : A5-07-01. You can select it in LM.
Threads: 8
Oh sorry...
i mean i try this profile (A5-07-01) but if i press the button and hold, the lamp switch on....when i release the button, the lamp switch off.
is it possible to make: one normal press the button = lamp on
and second time normal press the button = lamp off
Threads: 31
We can't change how the device works but you can make a script. Map the switch to a virtual object and create event script. Each time you receive off send opposite value to your control object.
Threads: 8
21.01.2020, 16:34
(This post was last modified: 21.01.2020, 16:46 by Tee_Trinker.)
hmm script... i don't know how it realy works :o
or can i find it in FB-Editor?
Threads: 31
Create virtual bit object, to which you will link your switch. Create event based script on your virtual object and past this.
lampAddress= '0/0/7'
value = event.getvalue()
lamp = grp.getvalue(lampAddress)
if value == false then
if (lamp == true) then
grp.write(lampAddress, false)
grp.write(lampAddress, true)
Change the lampAddres which is group of your light.
Threads: 8
21.01.2020, 18:17
(This post was last modified: 21.01.2020, 18:27 by Tee_Trinker.)
i create it, but its the same...
when i press the button the lamp comes on and when i let go it goes out.
but it should stay on. the lamp should only be off when I press again
like a changeover switch
sorry for my Englisch
Threads: 31
because you linked the lamp directly and I asked you to do it via virtual object. In enocean tab link switch object to virtual object.
Threads: 8
21.01.2020, 18:54
(This post was last modified: 21.01.2020, 18:55 by Tee_Trinker.)
i create a virtual object, then the event based script....changed the lamp addrres, but its the same.
what do i wrong?
lampAddress= '0/0/24'
Threads: 31
Did you link the Eltako FTTB to virtual object?
Threads: 8
yes its 31/1/54
i create a new virtual object.
link to eltako with A5-07-01 Profil
Threads: 31
If you disable the script, can you still control the lamp?
Threads: 8
Hi Daniel,
Probably not as he is using the profile combined with the script.
He needs to use a raw 4 byte profile and see the value on release, probably 76 or something.
Then the script must be if event.getvalue() == 76 then ...
This way you bypass the “doorbell button” function that the A5 profile is doing.
Threads: 8
no...if its disable i can not control the lamp
Threads: 31
(22.01.2020, 14:47)Erwin van der Zwart Wrote: Hi Daniel,
It is the same only you save one object. With profile on release must be off.
Log the virtual object and let me know what you get when pressed and released.
Threads: 31
OK then Erwin is right. Change profile to 4byte Raw and link it to new virtual object and log the values again.
Threads: 8
You are still using a bit object..
Create a 4 byte virtual object and attach the enocean remote via a 4 byte raw profile to the 4 byte object.
Add a event based script to your new 4 byte object and log the value by log(event.getvalue())
Send us the value that is generated on release of your button so we can adjust the script for you.
Threads: 31
Can you just write what value you have on release, I hardly can see it on the image
