Anyone an idea why IP settings are not visible anymore? LM5lp (i.MX6)- firmware 20180822
Thx
Thx
IP settings
Anyone an idea why IP settings are not visible anymore? LM5lp (i.MX6)- firmware 20180822 Thx
07.02.2020, 17:16
Try clearing browser cache.. BR, Erwin
07.02.2020, 17:25
07.02.2020, 17:37
Do any other forms work? Do you have any errors in browser console (F12)?
07.02.2020, 17:47
(07.02.2020, 17:37)admin Wrote: Do any other forms work? Do you have any errors in browser console (F12)?Not that I know. I have acces to LM, everything seems ok
Gr.
Geert (07.02.2020, 17:54)Daniel. Wrote: Any info in system logs? Screenshot system log (07.02.2020, 18:09)Geert Wrote:(07.02.2020, 17:54)Daniel. Wrote: Any info in system logs? With explorer and firefox it's possible to see settings, with chrome not. Also not after removing cache
Gr.
Geert
07.02.2020, 18:37
Must be cache related, are you sure you delete all history and not ’last hour’ (that is default)? BR, Erwin
07.02.2020, 18:43
(07.02.2020, 18:37)Erwin van der Zwart Wrote: Hi, No, I know it must be cache related but I deleted all history. Several times now...
Gr.
Geert
10.02.2020, 08:18
What if you open Chrome in incognito window?
11.02.2020, 07:50
Can you provide remote access to your device? Have you tried installing 2019 RC1 firmware?
(10.02.2020, 08:18)Daniel. Wrote: What if you open Chrome in incognito window? Result when opening in Chrome in incognito is the same, settings not visible. (11.02.2020, 07:50)admin Wrote: Can you provide remote access to your device? Have you tried installing 2019 RC1 firmware? No, I haven't changed to new firmware. I'd rather like to do that with a device that's not in the field. Remote access is possible.
Gr.
Geert
12.02.2020, 09:34
Hello, the same thing happens to me too, it has to be a problem of some recent Chrome browser update. What happens is that the letters are not seen, if you try to select to make a copy / paste you will see that you copy them perfectly. With other browsers it goes perfect. I have LM updated to last firm.
Greetings
12.02.2020, 09:54
True, I had older version of Chrome and all worked fine, now after update all gone.
12.02.2020, 11:34
Looks like a bug in Chrome. I've tried latest dev version (82) and it's still present. Most probably we will have to implement a work-around for this.
« Next Oldest | Next Newest »
