Threads: 2
17.02.2020, 09:58
(This post was last modified: 17.02.2020, 10:00 by arnocl.)
Is there anybody who got the IP Control function of the more recent Sony Bravia TV working? I'm able to post a HTTP request trough my phone, only after pairing the device with the TV first with the default sony app. On my PC this is a little more complicated, but after following this guide (post Jul 08, 2015) this seems to work correctly. The PC appears on my TV in the list of trusted devices, along with my phone. The POST request requires to input a pincode visualized on the screen after starting the request.
Quote:1. Install Google Chrome
2. Install Simple Rest Client (https://chrome.google.com/webstore/detail/simple-rest-client/fhjcajmcbmldlhcimfajhfbgofnpcjmb)
3. Once Simple Rest Client is installed you should see a blue globe looking icon to the right of the URL field in Chrome. Click on that icon.
4. In the URL field of the REST Client, type in http://192.168.168.198/sony/accessControl
where you replace 192.168.168.198 with IP address of your TV.
5. Click on POST.
6. In the DATA field paste:
{"id":13,"method":"actRegister","version":"1.0","params":[{"clientid":"iRule:1","nickname":"iRule"},[{"clientid":"iRule:1","value":"yes","nickname":"iRule","function":"WOL"}]]}
7. Hit SEND. You should see a message on TV pop-up with PIN code and a Username and Password message pop-up in the Browser.
Leave Username blank and in password field put in the PIN code that is displayed on TV.
It seems the TV needs to trust the device sending requests. Is there a way to enable this with the logicmachine? Previous threads don't seem to work in my case ( Sony Bravia script and Sony Simple IP Protocol).
This is the code I tried to use:
Code: function ipControlTV(service, cmd)
require('socket')
ip = "192.168.1.135"
port = 80
host = "http://" .. ip .. "/sony/" .. service
reqs = "POST /sony/" .. service .. " HTTP/1.1 \r\n" ..
"HOST: " .. ip .. " \r\n" ..
"X-Auth-PSK: **** \r\n" ..
"Content-Type: application/json; charset=UTF-8 \r\n " ..
"\r\n" .. cmd .. "\r\n\r\n"
sock = socket.tcp()
sock:settimeout(3)
res, err = sock:connect(ip, port)
if res then
res, err = sock:send(reqs)
if res then
log(res,err)
log('send failed: ' .. tostring(err))
log('connect failed: ' .. tostring(err))
sock:close()
And to call my code (toggle of power object):
Code: power = event.getvalue()
command = ""
if (power) then
command = '{ \\"method\\": \\"setPowerStatus\\", \\"id\\": 55, \\"params\\": [{\\"status\\": true}], \\"version\\": \\"1.0\\" }'
command = '{ \\"method\\": \\"setPowerStatus\\", \\"id\\": 55, \\"params\\": [{\\"status\\": false}], \\"version\\": \\"1.0\\" }'
ipControlTV("system", command)
I keep getting the following error:
Code: * arg: 1
* string: JSON Format Error
* arg: 2
* number: 400
Just remove all \\ from command strings.
More correct approach is to encode data via JSON:
Code: require('json')
command = json.encode({
method = 'setPowerStatus',
id = 55,
version = '1.0',
params = {
{ status = power }
Threads: 44
17.02.2020, 19:13
(This post was last modified: 17.02.2020, 23:40 by benanderson_475.)
Why do you try Http post command to a tcp socket??
Try this, i have it working on Sony 2019 tv with no auth required as such (apart from the Xauth-psk as defined in the tv settings) also the protocol is well documented here
https://pro-bravia.sony.net/develop/inte...index.html
i just started learning lua so im sure there are some improvements to make to this script.
Change ip adress below to match tv and update ["X-Auth-PSK"] = "123456789", with your pre shared key from the tv
Code: local http = require("socket.http")
local ltn12 = require("ltn12")
require('json')
local path_system = "http://192.168.1.21/sony/system"
local path_avContent = 'http://192.168.1.21/sony/avContent'
local payl = {
Pwr_on = [[ {"method": "setPowerStatus","id": 55,"params": [{"status": true}],"version": "1.0"} ]], --/system
Pwr_off = [[ {"method": "setPowerStatus","id": 55,"params": [{"status": false}],"version": "1.0"} ]], --/system
Pwr_req = [[ {"method": "getPowerStatus","id": 50,"params": [],"version": "1.0"} ]], --/system
Pwr_Get_system = [[{"method": "getSystemInformation","id": 33,"params": [],"version": "1.0"}]],
Set_input_hdmi3 = [[ {"method": "setPlayContent","id": 101,"params": [{"uri": "extInput:hdmi?port=3"}],"version": "1.0"} ]], --/avContent
Set_req = [[ {"method": "getPlayingContentInfo","id": 103,"params": [],"version": "1.0"} ]], --/avContent
vol_set = [[ {"method": "setAudioVolume","id": 98,"params": [{"volume": "5","ui": "on","target": "speaker"}],"version": "1.2"} ]], -- /audio
vol_req = [[ {"method": "getVolumeInformation", "id": 33, "params": [], "version": "1.0"} ]], -- /audio
reboot = [[ {"method": "requestReboot","id": 10,"params": [],"version": "1.0"} ]] --/system
--********///////////// Main Command ////////////********--
function sony_do_cmd(sony_cmd) -- 'Pwr_on' , 'Pwr_off' for power on call function, sony_do_cmd('Pwr_on')
-- is pwr command set url
pwr = string.match(sony_cmd, "Pwr_")
set = string.match(sony_cmd, "Set_")
if pwr then
path = path_system
payload = payl[sony_cmd]
if set then
path = path_avContent
local response_body = { }
local res, code, response_headers, status = http.request
url = path,
method = "POST",
headers =
["Accept"] = "*/*",
["Content-Type"] = "application/x-www-form-urlencoded",
["Content-Length"] = payload:len()
source = ltn12.source.string(payload),
sink = ltn12.sink.table(response_body)
log(json.decode(response_body))
Threads: 2
Thanks @benanderson_475 for pointing me in the right direction! Everything is working as it should, guess I got a little mixed up. The guide is indeed self explanatory.
Threads: 2
22.02.2020, 09:29
(This post was last modified: 22.02.2020, 09:39 by arnocl.)
I cleaned up your code a little to be tailored more to my needs. Also included a status object checker, convenient to get a feedback of the actual settings of the TV.
Common Functions:
Code: function ipControlSonyTV(service, command)
require("json")
local ip = "192.168.1.135"
url = "http://" .. ip .. "/sony/" .. service,
method = "POST",
headers =
["HOST"] = ip,
["Accept"] = "*/*",
["X-Auth-PSK"] = "************",
["Content-Length"] = command:len()
source = ltn12.source.string(command),
response = json.decode(response_body[1])
return response["result"][1]
Resident Script (every 2 seconds or as much as needed):
Code: command = [[ {"method": "getPowerStatus","id": 50,"params": [],"version": "1.0"} ]]
powerStatus = ipControlSonyTV("system", command)
powerStatus = powerStatus["status"]
if (powerStatus == "active") then
grp.checkwrite('5/0/2', 1, 1)
elseif (powerStatus == "standby") then
grp.checkwrite('5/0/2', 0, 1)
command = [[ {"method": "getVolumeInformation", "id": 33, "params": [], "version": "1.0"} ]]
volumeInfo = ipControlSonyTV("audio", command)
volumeStatus = volumeInfo[1]["volume"]
muteStatus = volumeInfo[1]["mute"]
grp.checkwrite('5/0/5', volumeStatus, 1)
grp.checkwrite('5/0/7', muteStatus, 1)
command = [[ {"method": "getPlayingContentInfo","id": 103,"params": [],"version": "1.0"} ]]
sourceStatus = ipControlSonyTV("avContent", command)
sourceStatus = sourceStatus["uri"]
sourceStatus = tonumber(string.sub(sourceStatus, -1))
grp.checkwrite('5/0/9', sourceStatus, 1)
Every control object has it's own event script
Power:
if (power) then
command = [[ {"method": "setPowerStatus","id": 55,"params": [{"status": true}],"version": "1.0"} ]]
command = [[ {"method": "setPowerStatus","id": 55,"params": [{"status": false}],"version": "1.0"} ]]
Volume Step:
Code: volumeDown = event.getvalue() -- down = 1 | up = 0
if (volumeDown) then
command = [[ {"method": "setAudioVolume","id": 98,"params": [{"volume": "-1","ui": "on","target": "speaker"}],"version": "1.2"} ]]
command = [[ {"method": "setAudioVolume","id": 98,"params": [{"volume": "+1","ui": "on","target": "speaker"}],"version": "1.2"} ]]
Volume:
Code: volume = event.getvalue()
command = [[ {"method": "setAudioVolume","id": 98,"params": [{"volume": "]] .. volume .. [[","ui": "on","target": "speaker"}],"version": "1.2"} ]]
Mute:
Code: mute = event.getvalue()
if (mute) then
command = [[ {"method": "setAudioMute","id": 601,"params": [{"status": true}],"version": "1.0"} ]]
command = [[ {"method": "setAudioMute","id": 601,"params": [{"status": false}],"version": "1.0"} ]]
Source Select:
Code: source = event.getvalue()
power = grp.getvalue('5/0/2')
if (not power) then
grp.write('5/0/1', 1)
os.sleep(1)
command = [[ {"method": "setPlayContent","id": 101,"params": [{"uri": "extInput:hdmi?port=]] .. source .. [["}],"version": "1.0"} ]]
Threads: 44
23.09.2020, 03:45
(This post was last modified: 23.09.2020, 03:46 by benanderson_475.)
in case anyone can use it, Updated user library for sony tv ip control
Sony_ip = '192.168.1.6'
X_Auth_Psk = "XXXXXXX9"
path_system = '/sony/system'
path_avContent = '/sony/avContent'
path_audio = '/sony/audio'
path_ircc = '/sony/IRCC'
function Sony_request(host, url, payload)
ltn12 = require('ltn12')
http = require('socket.http')
response_body = {}
res, err = http.request{
url = 'http://' .. host .. url,
method = 'POST',
headers =
["Accept"] = "*/*",
["X-Auth-PSK"] = X_Auth_Psk,
if response_body then
-- log(response_body)
resp = json.encode(response_body)
resp = json.decode(resp)
-- log(resp)
if resp[2] then
resp = table.concat(resp)
resp = json.decode(resp[1])
return resp
return nil, err
function Sony_Soap_request(host, url, IRCC)
local body, http, ltn12, sink, res, err
body = [[<?xml version="1.0"?>
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"
s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<s:Body>
<u:X_SendIRCC xmlns:u="urn:schemas-sony-com:service:IRCC:1">
<IRCCCode>]]..IRCC..[[</IRCCCode>
</u:X_SendIRCC>
</s:Body></s:Envelope>]]
Soap_response_body = {}
method = 'POST',
headers =
["Host"] = host,
["Connection"] = "keep-alive",
["Accept"] = "*/*",
["Content-Type"] = "text/xml; charset=UTF-8",
["Content-Length"] = #body,
["Soapaction"] = '"urn:schemas-sony-com:service:IRCC:1#X_SendIRCC"'
source = ltn12.source.string(body),
sink = ltn12.sink.table(Soap_response_body)
if Soap_response_body then
return Soap_response_body
return nil, err
function encode_json_message(method, id, params, version)
json_msg = json.encode({
method = method,
id = id,
params = {params},
version = version
return json_msg
--************************* Command functions ****************************
function Sony_pwr(state)
Sony_request(Sony_ip, path_system, encode_json_message("setPowerStatus", 55, {status = state }, "1.0"))
function Sony_set_input_hdmi1()
Sony_request(Sony_ip, path_avContent, encode_json_message("setPlayContent", 101, {uri = "extInput:hdmi?port=1"}, "1.0"))
function Sony_set_input_hdmi2()
Sony_request(Sony_ip, path_avContent, encode_json_message("setPlayContent", 101, {uri = "extInput:hdmi?port=2"}, "1.0"))
function Sony_set_input_hdmi3()
Sony_request(Sony_ip, path_avContent, encode_json_message("setPlayContent", 101, {uri = "extInput:hdmi?port=3"}, "1.0"))
function Sony_set_input_tv()
Sony_request(Sony_ip, path_avContent, encode_json_message("setPlayContent", 101, {uri = "tv:dvbt"}, "1.0"))
function Sony_set_volume(level)
res = Sony_request(Sony_ip, path_audio, encode_json_message("setAudioVolume", 98, {volume = level, ui = "on", target = ""}, "1.2"))
function Sony_set_audio_mute(state)
Sony_request(Sony_ip, path_audio, encode_json_message("setAudioMute", 601, {status = state}, "1.0"))
--************************* Request Command functions ****************************
function Sony_get_playing_content()
json_msg = encode_json_message("getPlayingContentInfo", 103, {}, "1.0")
res = Sony_request(Sony_ip, path_avContent, json_msg)
--- update obj with new value
if not res.error then -- cant call this function if the display is off res.error[2] = Display Is Turned off
title = res.result[1].title
programme = res.result[1].programTitle
if title then
grp.write('1/1/1', title)
if programme then
grp.write('1/1/2', programme)
return title, programme
function Sony_get_power_status()
pwr_res = Sony_request(Sony_ip, path_system, encode_json_message("getPowerStatus", 50, {}, "1.0"))
pwr_res = pwr_res.result[1].status --active|standby
return pwr_res
function Sony_get_volume_info()
vol_res = Sony_request(Sony_ip, path_audio, encode_json_message("getVolumeInformation", 33, {}, "1.0"))
vol_res = vol_res.result[1][1].volume -- returns tv volume level
return vol_res
function Sony_get_remoteController_info()
res = Sony_request(Sony_ip, path_system, encode_json_message("getRemoteControllerInfo", 54, {}, "1.0"))
rc_codes = {}
res = res.result[2]
for i = 1, #res do
name = res[i].name
value = res[i].value
rc_codes[name] = value
-- log(rc_codes)
storage.set('RC_Codes', rc_codes)
return rc_codes
function req_channel_delayed(delay)
os.sleep(delay)
function Sony_send_key(IRCC_name) -- needs to send ircc with soap command...
--PartnerApp11, SyncMenu, FeaturedApp, MuteOff, MuteOn, AudioMixUp Teletext, AudioOutput_TVSpeaker, partnerApp10, BS, ActionMenu, SleepTimer
--CS, AudioMixDown, TvInput, PartnerApp1, Forward, Hdmi3, DigitalToggle, Hdmi2, PartnerApp6, ApplicationLauncher, Blue, Stop, TvAntennaCable,
--Wide, Help, AudioOutput_AudioSystem, VolumeDown, Hdmi1, Tv, PartnerApp20, OneTouchTimeRec, Down, PartnerApp19, PopUpMenu, FeaturedAppVOD,
--Component2, Video1, Audio, Media, Digital, Num11, PartnerApp13, Mode3D, AndroidMenu, *AD, Component1, CursorRight, Enter, PhotoFrame, Sleep,
--PartnerApp2, Assists, ChannelUp, Right, DOT, RecorderMenu, FootballMode, Green, PartnerApp14, GooglePlay, AudioOutput_Toggle, EPG, SubTitle,
--FlashMinus, Input, PartnerApp18, PartnerApp5, ClosedCaption, PartnerApp16, PAP, PartnerApp15, PartnerApp12, PartnerApp9, TenKey, WakeUp
--PartnerApp7, PartnerApp17, Next, PartnerApp4, PartnerApp3, Analog, PictureMode, STBMenu, TvSatellite, Jump, BSCS, Rec, Hdmi4, Ddata, YouTube
--Mute, ChannelDown, OneTouchView, Home, AnalogRgb1, PictureOff, Num2, TvAnalog, Tv_Radio, , CursorDown, Num3, Num0, WirelessSubwoofer, Video2,
--Confirm, DemoMode, Left, Num1, ShopRemoteControlForcedDynamic, FlashPlus, Display, Num6, GGuide, PartnerApp8, Prev, Num7, Num4, Play, Red,
--TopMenu, Num5, Analog2, DUX, Return, VolumeUp, DpadCenter, Options, Num12, PicOff, Rewind, iManual, DemoSurround, MediaAudioTrack, Up, TvPower,
rc_codes = storage.get('RC_Codes')
if not rc_codes then
rc_codes = Sony_get_remoteController_info()
IRCC_key_name = rc_codes[IRCC_name]
Sony_Soap_request(Sony_ip, path_ircc, IRCC_key_name)
if IRCC_name == "ChannelDown" or IRCC_name == "ChannelUp" then
req_channel_delayed(0.5)
function Sony_get_content_count()
res = Sony_request(Sony_ip, path_avContent, encode_json_message("getContentCount", 11, {source = "tv:dvbt"}, "1.1"))
return res.result[1].count
function Sony_get_content_list()
local num = Sony_get_content_count()
res = Sony_request(Sony_ip, path_avContent, encode_json_message("getContentList", 88, {stIdx = 0, cnt = num, uri = "tv:dvbt"}, "1.5"))
res = res.result[1]
uri_s= {}
for i = 1, #res do
uri = res[i].uri
title = res[i].title
uri_s[title] = uri
--- log(uri_s)
storage.set('Chan_uri', uri_s)
return uri_s
function Sony_Chanell(chan) -- chan is uri name and is returned by Sony_get_content_list() uncomment log(uri_s) above and call function Sony_get_content_list() to see what they are
uri_C = storage.get('Chan_uri')
if not uri_C then
uri_C = Sony_get_content_count()
res = Sony_request(Sony_ip, path_avContent, encode_json_message("setPlayContent", 101, {uri = uri_C[chan]}, "1.0"))
req_channel_delayed(0.2)
return res
Threads: 3
(22.02.2020, 09:29)arnocl Wrote: I cleaned up your code a little to be tailored more to my needs. Also included a status object checker, convenient to get a feedback of the actual settings of the TV.
Common Functions:
require("json")
method = "POST",
headers =
["HOST"] = ip,
["Accept"] = "*/*",
Power:
if (power) then
Volume Step:
Volume:
Mute:
if (mute) then
Source Select:
if (not power) then
os.sleep(1)
Hi guys,
i try this Scripts and got error
Code: Common functions:144: bad argument #1 to 'decode' (string expected, got nil)
stack traceback:
[C]: in function 'decode'
Common functions:144: in function 'ipControlSonyTV'
Can you help me?
I dont know much about scripting.
Just a little less than basics.
Threads: 31
