Switching sunrise/sunset-dependent light
Hello, everybody,
i would like to write a script that switches the light independently from sunset or sunrise.
For example:
sunrise + 0 hours
40% Dimming
Sunrise + 2 hours
100% Dimming
Sunrise + 5 hours
100% Dimming
Sunset - 4 hours
100%
Sunset - 2 hours
100%
Sunset - 2 hours
100%
sunset + 0 hours
80% Dimming
Sunset + 1 hour
50% Dimming
Sunset + 2 hours
30% Dimming
Sunset + 3 hours
15 % Dimming
How would the script for this look like? How can I use sunset + sunrise for this?
Thanks a lot
Chris
Easiest way is to you use a scheduler with sunrise / sunset settings.
(24.03.2020, 07:45)Joep Wrote: Easiest way is to you use a scheduler with sunrise / sunset settings.
i need a script, because the motion detector should switch the light dependent.
i.e. if group address = 1 with motion detector then dependent switching.
You can create a virtual object that the scheduler will use. Then create a script that will act as a gate so the value is only written when the motion detector is off.
