06.04.2020, 19:41
Is there a posibillity to put a schedular of some sort in Mosaic?
Schedular Mosaic.
06.04.2020, 19:41
07.04.2020, 07:30
The only way is via using frame but it will have to be quite big.
In new Mosaic Beta we added dedicated widget Scheduler but I wouldn't use this version yet on customer project.
17.04.2020, 09:30
(07.04.2020, 07:30)Daniel. Wrote: The only way is via using frame but it will have to be quite big. Hi Daniel, on Mosaic is there the opportunity to open the scheduler simply with a pop up when a bottom is pressed or you suggest to use a page for the scheduler? I tried it and when I test it with my PC there is not problem instead with a tablet Android 10" and by phone does not work. What do you suggest? Thanks.
17.04.2020, 10:15
I think the only option without writing custom widget is what you did. It probably is not working on mobile as when a widget is too big for a screen it is not shown.
17.04.2020, 10:35
(17.04.2020, 10:15)Daniel. Wrote: I think the only option without writing custom widget is what you did. It probably is not working on mobile as when a widget is too big for a screen it is not shown. I need to find out the best solution. I do not understand how can I build a scheduler by custom widget. Thank you.
17.04.2020, 11:04
When I say custom widget I mean writing it from scratch in code, not via using the build editor.
17.04.2020, 11:18
17.04.2020, 12:32
Sorry but I do not want to promises anything now. We have limited development due to covid19
Ctrl+F5 |
« Next Oldest | Next Newest »
