Logger All Datagrams KNX BUS to mysql
Hello I have a project in which I need to save in a bbdd mysql all the states of all KNX groups in real time.
In other words, I need to listen to the KNX BUS and send all the datagrams that are written to the BUS to a mysql DB.
Can LM do this?
Can somebody help me?.
Thank you.
See this thread on a basic example of bus monitoring. It can be easily extended to send data to mysql or any other database:
https://forum.logicmachine.net/showthread.php?tid=273
Maybe an idea would be, to mark all the objects with "LOG" and every hour, to synchronize the objects of the LM bbdd with the DB of mysql?
You can modify CSV example to export to mysql: https://openrb.com/example-export-last-h...-from-lm2/
This is my code, maybe not perfect but it works
* table:
[datalen]
  * number: 4
[datahex]
  * string: 453FE000
[data]
  * number: 3070
[srcraw]
  * number: 8448
[dstraw]
  * number: 17930
[type]
  * string: groupwrite
[src]
  * string: 2.1.0
[dst]
  * string: 8/6/10
if not client then
  require('genohm-scada.eibdgm')
  objects = grp.all()
  datatypes = {}
  for _, object in ipairs(objects) do
    datatypes[ object.id ] = {object.name, object.datatype}
  function writemysql(I_datalen,I_datahex,I_data,I_srcraw,I_dstraw,I_type,I_src,I_dst,I_name)
      require('luasql.mysql')
    env = luasql.mysql()
    dbcon = env:connect('xxxxxxxxx', 'xxxxxxx', 'xxxxxxxx', '192.168.12.25', '3306')
    if dbcon then
      if I_type == 'groupread' then
        cursor = dbcon:execute( 'insert into datalog (datetime,datalen,srcraw,dstraw,type,src,dst,dstname) values (now(),'..I_datalen..','..I_srcraw..','..I_dstraw..',"'..I_type..'","'..I_src..'","'..I_dst..'","'..I_name..'") ' )
          cursor = dbcon:execute( 'insert into datalog (datetime,datalen,datahex,data,srcraw,dstraw,type,src,dst,dstname) values (now(),'..I_datalen..',"'..I_datahex..'",'..tostring(I_data)..','..I_srcraw..','..I_dstraw..',"'..I_type..'","'..I_src..'","'..I_dst..'","'..I_name..'") ' )
      --log(cursor)
      dbcon:close()
      env:close()
  function writehandler(event)
    if datatypes[ event.dstraw ] then
      name = datatypes[ event.dstraw ][1]
        dpt = datatypes[ event.dstraw ][2]
      name = ''
    if dpt then
      event.data = knxdatatype.decode(event.datahex, dpt)
        event.data = nil
    --log(event)
    writemysql(event.datalen,event.datahex,event.data,event.srcraw,event.dstraw,event.type,event.src,event.dst,name)
  function readhandler(event)
      name = ''
    --log(event)
    writemysql(event.datalen,event.datahex,'',event.srcraw,event.dstraw,event.type,event.src,event.dst,name)
  -- knx connection
  client = eibdgm:new({ timeout = 1 })
  client:sethandler('groupwrite', writehandler)
  client:sethandler('groupresponse', writehandler)
  client:sethandler('groupread', readhandler)
-- handle knx
client:step()
