Logic machine as bacnet ms/tp slave
Good companions, I hope you are excellent. I am writing to tell you if it is possible with the logic machine, read the variables of a meter that is Bacnet IP and pass it to Bacnet ms / tp through the RS485 ports it has. I have read in several threads that the logic machine does not accept Bacnet ms / tp, but maybe with the new firmware changes that have been made, it may be possible, so that's why I'm asking. Thank you and I will be attentive to your comments
The only change in Bacnet were the bacnet units. Nothing new regarding MS/TP
Ok. Thank you.
