Video Intercom with LM
Hello! Has anyone integrated a video intercom with LM?
I want to add to visu, a page dedicated to video intercom, where you can view and give access.
In the installation I have an all-in-one pc screen, just for viewing.
I don't want to use external applications outside of LM if possible.
Only video is possible with for example a doorbird intercom, you can add a http command to the pushbutton and trigger a knx address with the remote services, switch to a page and show video stream etcetera. VOIP is a different story as browsers use webrtc for that and requires a secure websocket including CA certificates with expiration. So yes possible, but for from easy and impossible to maintain.
I've found interesting solution for door intercom which can be integrated with LM:
https://www.doorbird.com/widget
It has very good parameters e.g. hemispheric camera and good quality. It has also opened API and support HTML widgets in browser.
Done is better than perfect
Hi, more and more is used the indoor intercom touchscreen as a user interface. Just installing the app in Android based intercoms you get the intercom functions from the outdoor panel (no integration needed) and the user interface for home automation (just an app installed as in the smartphone). So integration is reduced to minimum. You can get more info in the following link https://meet.fermax.com/integration-meet-works-with
.pdf   LOGICMACHINE_MEET_IN.pdf (Size: 1.75 MB / Downloads: 39)
.pdf   CASE-STUDY-TEC-LOGICMACHINE_EN.pdf (Size: 374.39 KB / Downloads: 27)
