Threads: 14
In the general options of a switch widget I can select "Functions" and then this widget appears directly in the Functions submenu of the main menú.
How can I select a Function for a Termostat widget? I can't see this option in the configuration
Threads: 35
The predefined widgets got function predefined too. Thermostat belongs to climate function.
Threads: 35
I just checked and the function definition is missing in this widget. I tried to modify this widget but for some reason could not add new to Mosaic. Will check with dev and update you.
Threads: 35
This topic is second on the development/fix list should be done soon.
Threads: 35
(26.05.2020, 15:24)pentadom Wrote: (26.05.2020, 12:52)Daniel. Wrote: This topic is second on the development/fix list should be done soon.
Thank you Daniel. I must update anything in the LM when the new fix is finished?
I will let you know.
Threads: 35
Update Mosaic and clear the cache.
