Api Error
Hello
I am trying to read this data with the Api provided by the manufacturer and I am having problems as it gives me the following error.
when I try to read item "1"
    Error de sintaxis en la linea 28: ')' expected near '.1'
Assistant screenshot
The first thing I have to do is comment on the following variables because otherwise I can't read anything
--potencia = data.PAC.Values
--total = data.TOTAL_ENERGY
so that at least read the variable "day"
and point only to the "Values" element so that it returns the 2 values in the "log"
Where is the error, how could I read all the values of the elements?
Thank you
API
  "Body":{
      "Data":{
        "DAY_ENERGY":{
            "Unit":"Wh",
            "Values":{
              "1":56350,
              "2":85580
        "PAC":{
            "Unit":"W",
            "Values":{
              "1":7018,
              "2":10434
        "TOTAL_ENERGY":{
            "Unit":"Wh",
            "Values":{
              "1":7979740,
              "2":6941850
        "YEAR_ENERGY":{
            "Unit":"Wh",
            "Values":{
              "1":4525021,
              "2":6941852
  "Head":{
      "RequestArguments":{
        "DeviceClass":"Inverter",
        "Scope":"System"
      "Status":{
        "Code":0,
        "Reason":"",
        "UserMessage":""
      "Timestamp":"2020-05-20T16:45:38+02:00"
Post your script and what do you get when you log data?
Are you trying to read this JSON direct (not possible to do, so your error might come from there) or do you have json.pdecode somewhere to convert it to a LUA table?
What i see in first sight is your table has other fields, first of all Data is with a capital D so the fields should be tablename.Data.PAC.Values but i also see a main wrapping table called Body so shouldn’t your code be tablename.Body.Data.PAC.Values ?
(20.05.2020, 18:00)Erwin van der Zwart Wrote: Hi,
Hi Erwin
I have a json.decode somewhere to convert it to a LUA table
effectively the problem was capital D but when I try to read the Value of field 1 with the following command
Line 21    day = data.Body.Data.DAY_ENERGY.Values.1
"Body":{
      "Data":{
        "DAY_ENERGY":{
            "Unit":"Wh",
            "Values":{
              "1":56350,
              "2":85580
it gives me a syntax error
Error de sintaxis en la linea 21: ')' expected near '.1'
If I execute the sentence as follows
I open the registration window I see the 2 values perfectly
How can I read the value 1 and 2 from the table?
I do not know how to send a screenshot to send the script because when I give the insert image icon it asks me for a URL or how to send a screenshot
Thank you
You can paste it as text or use attachment to add image. Log data and paste the result here
Try: data.Body.Data.DAY_ENERGY.Values[1] or data.Body.Data.DAY_ENERGY.Values['1']
(21.05.2020, 19:24)Erwin van der Zwart Wrote: Hi,
Thank you very much that was the mistake
it's ready   Wink
