Threads: 29
Works fine for me, did you tried to logout, login again and then sync? You can also ask Alexa to discover.
Threads: 29
Do you still have the ''Alexa --> Error description: Line 777: MQTT.clientConfusedubscribe(): Not connected'' or was it once some time ago?
Threads: 29
Make a backup then install Storage viewer app and delete the doxsx:alexa:devices and doxsx:alexa:devices2. After this you will have to setup alexa app again from scratch.
Threads: 29
The whole device backup, Alexa settings will be there too.
Threads: 29
Do you say that when you used another LM on the same network then it worked?
Threads: 29
The error you have in 99% means that outgoing port 1883 is blocked. Did anything changed in your network?
Threads: 29
The easiest test is by setting Mosaic with an object and try to control it from cloud.
Threads: 29
From LM to internet. you don't have to open any incoming ports.
You can try this software on PC
http://mqtt-explorer.com/
There is out of the box test.mosquitto.org broker. Check if you can connect to it. Keep everything default.
