Threads: 9
Good morning,
there is the possibility of transmitting events with this application (e.g. tripping protections, exceeded threshold, ..)
Threads: 13
It was explained here https://forum.logicmachine.net/showthrea...13#pid2513 but lets make a clear version:
1. Install Telegram app
2. Find BotFather or go here https://t.me/botfather
3. Once in BotFather type /newbot and follow instructions. As a result you will get your token and your own bot link like t.me/yourname_bot Click on the link and type any message there
4. Open browser (preferably Firefox as it converts JSON automatically) and go here https://api.telegram.org/bot<token>/getUpdates. Replace <token> with your token. As a result you should have something like that. Save your chat ID
5. Create a user library called telegram. paste this code and replace your token and chat ID
Code: function telegram(message)
local url = 'https://api.telegram.org/bot' .. token .. '/sendMessage'
local data = 'chat_id=' .. chat_id .. '&text=' .. socket.url.escape(message)
return ssl.https.request(url, data)
6. Create an event based script and use this code to send message to Telegram app:
Code: require("user.telegram")
message = 'test message'
res, err = telegram(message)
log(res, err)
Threads: 4
03.06.2020, 17:18
(This post was last modified: 03.06.2020, 17:19 by JRP.)
Hello
First of all thank you for your summary, precisely in the indicated thread I put a comment requesting a clear guide like yours.
I have done all the steps indicated and it doesn't work for me.
If I manually assemble the url to send messages and paste it in firefox, the message is sent and appears in telegram.
If I put the same token and the same chat id in the user script and create the event script, nothing happens when executing it.
I have modified the user script with a log, in addition to the one present in the event script. This is the result.
This is the user script code
Code: require('ssl.https')
local token = '110xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' -- your token
local chat_id = '-23xxxxxxxx' -- your chat id
local telegram_url = 'https://api.telegram.org/bot' .. token .. '/sendMessage?'
message=socket.url.escape(message)
local data_str = 'chat_id=' .. chat_id .. '&text=' .. message..''
local res, code, headers, status = ssl.https.request(telegram_url, data_str)
log(telegram_url, message, data_str, res, code, headers, status, ssl.https.request)
This is the event script
log(res, err)
Thank you.
a greeting
Threads: 13
Threads: 4
(03.06.2020, 18:02)Daniel. Wrote: what fw do you use? Hello
Thank you for your interest.
I have a wiser with version 2.4.0
a greeting
Threads: 13
03.06.2020, 18:40
(This post was last modified: 03.06.2020, 19:13 by Daniel..)
It will work in new FW 2.5.0 which should be available in a month time.
For older fw it will work like this
Code: function request(url)
local resp = {}
local stat, code, hdrs = require('ssl.https').request({
method = 'GET',
url = url,
protocol = 'tlsv12',
sink = ltn12.sink.table(resp),
if stat then
stat = table.concat(resp)
return stat, code, hdrs
local chat_id = '12345'
local token = 'wwwwwwwwwwwwwwwwwwwwwwwwww'
message = "test"
message=require('socket.url').escape(message)
stat, code, hdrs = request(telegram_url .. data_str)
Threads: 4
Hello
Thanks for the reply.
I'll wait for the update to launch.
Out of curiosity, why is it not working?
a greeting
Threads: 4
03.06.2020, 21:06
(This post was last modified: 03.06.2020, 21:08 by Erwin van der Zwart.)
Because there was a change in the http library that is included in the new FW..
Threads: 22
Older firmware uses SSLv3 for HTTPS requests by default. SSLv3 is disabled on most servers for security reasons so TLSv1.2 or newer must be used instead. HTTPS library in the new FW will use TLSv1.2 by default. The updated code that Daniel posted is perfectly fine and will work on all firmware versions.
Threads: 4
Hello
Thank you all for answering me.
It is interesting to know.
a greeting
Threads: 31
(04.06.2020, 04:36)admin Wrote: Older firmware uses SSLv3 for HTTPS requests by default. SSLv3 is disabled on most servers for security reasons so TLSv1.2 or newer must be used instead. HTTPS library in the new FW will use TLSv1.2 by default. The updated code that Daniel posted is perfectly fine and will work on all firmware versions.
I tried this code on firmware 20160714 and it fails:
Code: log("code: " ..tostring(code))
log("headers: " ..tostring(hdrs))
log("status: " ..tostring(stat))
test_telegram 04.06.2020 11:05:19
* string: status: nil
* string: headers: nil
* string: code: revcd alert fatal error
Threads: 22
Threads: 4
(01.06.2020, 14:29)Daniel. Wrote: It was explained here https://forum.logicmachine.net/showthrea...13#pid2513 but lets make a clear version:
local token = 'token' -- your token
local chat_id = '1234567' -- your chat id
log(res, err)
Thanks Daniel, with the Wiser 2.5.0 update, this script works perfectly and the instructions are very clear.
Thank you all so much for your help.
Threads: 51
04.08.2020, 09:03
(This post was last modified: 04.08.2020, 09:04 by phongvucba.)
Hi everybody ! I have shortened the following code to send a message! But it didn't work, I used LM5 RIO2E version 20170620, it still started at first, it doesn't work anymore.
I have tried the telegram bot on the web browser and it still works.
Is there any wrong code in my code?
Please everyone help. !
http= require('ssl.https')
socket.http.timeout = 10
noidung = 'Báo%20động%20có%20người%20đột%20nhập%20qua%20cửa%20sổ!'
local ip=http.request('https://api.telegram.org/bot.../sendmessage?chat_id=-731524114&text='..noidung..'')
log('dfdgdfgdfgdfg=' .. ip)
Threads: 13
Install new fw and use example above.
