Threads: 43
Is there a way to determine which user has logged on to the LM.
Would like to change the value of an Object to identify which user is logged in, so that various controls can be set to Read-Only depending on which user has logged on.
I have a script that enable and disable objects, so just need the bit to find the user ?
Thanks for help
engineer1 grp.write('1/1/1',1)
engineer2 grp.write('1/1/1',2)
Threads: 43
Thank You very much, will give it a try
Threads: 35
In the new FW we can check current user by Globals.user
No need for lp in this case. It will work only in RC2 or the new 2.5.0 for SE
$(function() {
var currentuser = Globals.user
if(currentuser === 'admin'){
// do action for admin
}else if(currentuser === 'erwin'){
// do action for erwin
Threads: 8
Yep, noticed it in the beta, cool (:
Threads: 43
Cool, how can I display the logged in user name on the main Vis page
Threads: 35
write it to the object
Threads: 43
So easy when you know how.
Thanks again for your continued support
Threads: 54
How can I log the actual user in the "objects log" ?
I want recording the user that had pressed the button.
KNX Advanced Partner + Tutor
Threads: 35
In latest fw it is done out of the box
Threads: 54
ok....now I saw !!
thanks !!
