send mail from gmail
Hi:
Since January it is not possible send mail from account gmail:
server = 'smtp.gmail.com',
    -- smtp server port
    port = 465,
    -- enable ssl, required for gmail smtp
secure = 'sslv23'
The configuration of client mail is:
REQUIRED SSL YES
REQUIRED TLS YES
PORT 587
I have changed the configuration and it doesn't work.
Hi use
secure = 'tlsv1_2',
(02.07.2020, 08:32)Daniel. Wrote: Hi use
  secure = 'tlsv1_2',
I've used that and  it doesn't work
Log
* arg: 1
* nil
* arg: 2
* string: closed
what FW do you use?
(02.07.2020, 08:51)Daniel. Wrote: what FW do you use?
I have several devices with differente FIRMWARE... and the same email configuration. One of them is 20170620
Can you try updating to RC1?
I have seen projects that are using a backup with older common function and that was the problem with mail..
Check if the function mail is like below:
-- send an e-mail function mail(to, subject, message)   -- make sure these settings are correct   local settings = {     -- "from" field, only e-mail must be specified here     from = 'user@gmail.com',     -- smtp username     user = 'user@gmail.com',     -- smtp password     password = 'password',     -- smtp server     server = 'smtp.gmail.com',     -- smtp server port     port = 465,     -- enable tls, required for gmail smtp     secure = 'tlsv1_2',   }   local smtp = require('socket.smtp')   if type(to) ~= 'table' then     to = { to }   end   for index, email in ipairs(to) do     to[ index ] = '<' .. tostring(email) .. '>'   end   -- fixup from field   local from = '<' .. tostring(settings.from) .. '>'   -- message headers and body   settings.source = smtp.message({     headers = {       to = table.concat(to, ', '),       subject = subject,       ['From'] = from,       ['Content-type'] = 'text/html; charset=utf-8',     },     body = message   })   settings.from = from   settings.rcpt = to   res, err = smtp.send(settings)   return res,err end
I had an issue where a cellphone was connected to the same Gmail account as I am using for alerts from LM, and the phone automaticly disabled the feature which accepts less secure applications. I had to remove the gmail account from the phone.
