Threads: 28
Hi All
Just to let you know that fw 2.5.0 for wiser for knx(homeLYnk) and spaceLYnk is out, you should find it on se.com
Threads: 7
If you have a HW1 and use the Wiser for KNX remote app just wait with updating as we are investigating the VPN connection...
If you have HW2/3 your good to go (:
Threads: 7
05.07.2020, 10:01
(This post was last modified: 05.07.2020, 10:02 by Erwin van der Zwart.)
Update: Fix for HW1 VPN connection will be released as .lmup update, so you can upgrade with this firmware and when you experience a issue to the Wiser for KNX remote app you might need to run this update.
Threads: 83
Thank you Erwin for info here, just on last Friday I updated SL (HW2) to latest version. Will wait update.
Alexander
Threads: 7
05.07.2020, 10:27
(This post was last modified: 05.07.2020, 10:28 by Erwin van der Zwart.)
HW2 does not require a update, VPN issue only applies to HW1 (older homeLYnk HW).
Next to that it does not apply to any SL HW as Wiser for KNX remote can’t be used on a SL (:
Threads: 0
06.07.2020, 12:27
(This post was last modified: 06.07.2020, 12:29 by iPedro.)
Hi guys,
I am new to the forum so I hope I am not asking question in the wrong place.
I have tried to upgrade my HL HWv1.2 to the FW2.5.0 from 2.4.0., but even if there is no error msg and process seems to be running fine on the end I am still on FW 2.4.0 - any advice ?
I should probably also mentioned that one of the reasons for me to run the upgrade is that I am facing issue with the HL that after a restart all changes or stored e.g. scripts disapears and go back to state of mid Feb.
Not sure if the two problems are linked, but would be greatfull for suggestion how to proceed.
Many thanks
Pedro
edit: I did click the "Sync project data"
Threads: 28
(06.07.2020, 12:27)iPedro Wrote: Hi guys,
Many thanks
Pedro
Your card is in read only mode and needs replacement
Threads: 0
Yep, that was it. I changed the card and FW is upgraded as well as reboot problem solved. Thanks a lot !!
Threads: 28
2.5.1 is coming with a fix.
Threads: 7
FW 2.5.1 is just released and should be available on our global website se.com.
Threads: 17
Does it come a 2.5.1 for HW2 & 3 aswell?
Threads: 28
(10.07.2020, 18:35)victor.back Wrote: Does it come a 2.5.1 for HW2 & 3 aswell?
Yes
Threads: 0
Where can I find the version 2.5.1 for HW3? When I download the firmware from Schneider it dosn´t include any .lmup file.
Andreas
Threads: 44
You need .img file for the firmware upgrade. It is installed through System config > System > Upgrade firmware.
