[OLD] LogicMachine firmware 2020.07
#81
(26.01.2021, 10:58)Daniel. Wrote: Just enable MQTT without encryption in the app and set MQTT explorer like this. If it won't connect then most likely it is firewall.
Hi Daniel,
this is exactly the set setup that I have, but I have tried to connect from my LAN (inside the firewall).
Regards Johan
(26.01.2021, 10:52)admin Wrote: Post full listing of your test script.
if not broker then
  broker = '127.0.0.1.'
  function multiply(mult)
    return function(value)
      local num = tonumber(value)
      if num then
        return num * mult
        return value
  -- topic to object map
  mqtt_to_object = {
    ['in/topic1'] = '1/1/1',
    ['in/topic2'] = '1/1/2',
  -- optional topic value conversion function
  mqtt_to_object_conv = {
    ['in/topic1'] = multiply(100),
    ['in/topic2'] = multiply(0.01),
  -- object to topic map
  object_to_mqtt = {
    ['1/1/1'] = 'out/topic1',
    ['1/1/2'] = 'out/topic2',
  datatypes = {}
  grp.sender = 'mq'
  require('socket')
  for addr, _ in pairs(object_to_mqtt) do
    local obj = grp.find(addr)
    if obj then
      datatypes[ addr ] = obj.datatype
  mclient = require('mosquitto').new()
  mclient.ON_LOG = log
  mclient.ON_CONNECT = function(res, ...)
    log('mqtt connect status', res, ...)
    if res then
      for topic, _ in pairs(mqtt_to_object) do
        mclient:subscribe(topic)
      mclient:disconnect()
  mclient.ON_MESSAGE = function(mid, topic, payload)
    local addr = mqtt_to_object[ topic ]
    if addr then
      local fn = mqtt_to_object_conv[ topic ]
      if fn then
        payload = fn(payload)
      grp.write(addr, payload)
  mclient.ON_DISCONNECT = function(...)
    log('mqtt disconnect', ...)
    mclientfd = nil
  function mconnect()
    local fd
    mclient:connect(broker)
    fd = mclient:socket()
    -- fd ref is valid
    if fd then
      mclientfd = fd
  mconnect()
  function publishvalue(event)
    -- message from us or client is not connected
    if event.sender == 'mq' or not mclientfd then
      return
    local addr = event.dst
    local dpt = datatypes[ addr ]
    local topic = object_to_mqtt[ addr ]
    -- unknown object
    if not dpt or not topic then
      return
    local value = busdatatype.decode(event.datahex, dpt)
    if value ~= nil then
      if type(value) == 'boolean' then
        value = value and 1 or 0
      mclient:publish(topic, tostring(value))
  lbclient = require('localbus').new(1)
  lbclient:sethandler('groupwrite', publishvalue)
  lbclientfd = socket.fdmaskset(lbclient:getfd(), 'r')
  -- run timer every 5 seconds
  timer = require('timerfd').new(5)
  timerfd = socket.fdmaskset(timer:getfd(), 'r')
-- mqtt connected
if mclientfd then
  mclientfdset = socket.fdmaskset(mclientfd, mclient:want_write() and 'rw' or 'r')
  res, lbclientstat, timerstat, mclientstat =
      socket.selectfds(10, lbclientfd, timerfd, mclientfdset)
-- mqtt not connected
  res, lbclientstat, timerstat =
    socket.selectfds(10, lbclientfd, timerfd)
if mclientfd and mclientstat then
  if socket.fdmaskread(mclientstat) then
    mclient:loop_read()
  if socket.fdmaskwrite(mclientstat) then
    mclient:loop_write()
if lbclientstat then
  lbclient:step()
if timerstat then
  -- clear armed timer
  timer:read()
  if mclientfd then
    mclient:loop_misc()
    mconnect()
I meant PC firewall.
Hi again,
I get some MQTT errors from Mosaic, see below.
#84
You have an extra dot in the broker address: broker = '127.0.0.1.'
#85
(26.01.2021, 12:31)admin Wrote: You have an extra dot in the broker address: broker = '127.0.0.1.'
Thanks, works perfect now
(26.01.2021, 12:26)Daniel. Wrote: I meant PC firewall.
Thanks, will check that
#86
I try to wake up this thread
hope everybody is safe
do you know when we will have a chance to see an official release ?
Cheers
#87
Next week we're publishing new firmware beta version.
#88
and GA ??
personally i'm not confortable to put a beta on a working home !!!!
#89
hello everyone please give us more information about the synchronization between the new mosiac beta and the cloud of logic machine, also give us more information about the mqtt app. After of the beta update how can i sync with the cloud???
      Best regards,
            Chris Balatis
#90
(07.04.2021, 19:02)balatis Wrote: hello everyone please give us more information about the synchronization between the new mosiac beta and the cloud of logic machine, also give us more information about the mqtt app. After of the beta update how can i sync with the cloud???
      Best regards,
            Chris Balatis
https://forum.logicmachine.net/showthrea...9#pid21069
