[Solved] SpaceLYnk not booting
I was doing a factory reset to my spacelynk due to a major change in my project (and honestly, I couldn't remember the password after being away due to Covid) but it didn't worked
Then I discovered that I could no longer communicate with it, although it was discoverable in my network (it kept the same address that was different from the factory one).
I have used Schneider's "AN103_How to fix issue with bootloader" instructions but it just does not work at all.
Is just makes the green led pulse in oposition to a red one on its inside.
Can someone help, please?
Thank you,
Julio
Please describe status of both LEDs
(13.07.2020, 07:24)Daniel. Wrote: Please describe status of both LEDs
Hi Daniel,
With original image file, interior LED is off and exterior LEDs have normal operation, flashing like they usually did. But I cannot communicate with it, although it is discoverable with Advanced IP Scanner.
After installing rec2.img from Schneider's bootloader fix:
LED 2 is off
LED 1 flashes twice, repeatedly  (like a heartbeat)
LED in the interior (color red) flashes opposite to LED1.
The problem may be with the SD Card, but then, it shouldn't allow to save a new image, correct?
Thanks for your help.
I would recommend you to flash the card. SE has AN for this too.
This is normal behaviour, rec2.img is only booting the device (without having a FW version), after that you are forced to upgrade to the desired FW.
I think you need to clear your browser cache to get the FW upgrade prompt..
Hi Erwin,
Thank you for your help.
The device is now up and running like a charm! Wink
Julio
