Mosaic creator
I'm practicing making widgets and when I see a widget available like the picture I can press the sun icon to open up other options. I tried a lot in the creator section and didn't know how to do it. Huh
Can someone just help me on how to do it !
This is not possible via creator, Such widgets are predefined and this is hard coded.
(17.07.2020, 10:58)Daniel. Wrote: This is not possible via creator, Such widgets are predefined and this is hard coded.
Oh, I hope this can be done on creators soon
Can you share the code?
OK but you really need to know what you are doing.
.gz   m-air-condition.tar.gz (Size: 6.03 KB / Downloads: 53)
Thank you very much. Let me try to edit it to creat a new widget
I fixed it and I don't know how to upload the mosaic
send it back and I will check
(20.07.2020, 08:50)Daniel. Wrote: OK but you really need to know what you are doing.
(23.07.2020, 11:37)Daniel. Wrote: send it back and I will check
Here you are. What I did change is:
Widget ID:
[Image: HS4DHIk.png]
value sent when you tap on each climate mode icon
[Image: eUTjxUn.png]
Power mode change to 3-step control
[Image: Vl5rFw7.png]
[Image: LiCrA6X.png]
Then I use PeaZip to compress the folder that contain the files to .tar.gz, but when I try to upload it to Mosaic, it didn't appear
[Image: 4gTZ99w.png]
I did some changes in css file but only replace the new icon
Can you just send it as file?
(25.07.2020, 07:12)Daniel. Wrote: Can you just send it as file?
I added it in the previous post but I dont know why it is missing.
.gz   Air.tar.gz (Size: 6.01 KB / Downloads: 14)
The widget looks ok but there seems to be some issue in mosaic with adding custom widgets. I will ask developer to look at it.
Hi the import works only the issue was in the folder structure. Attached the corrected structure.
While importing it is important that the key match the one in script, in this case it is gamma_air.
Refresh after import.
.gz   Air.tar.gz (Size: 5.98 KB / Downloads: 30)
(05.08.2020, 07:49)Daniel. Wrote: Hi the import works only the issue was in the folder structure. Attached the corrected structure.
Thank you let me try
How to call that widget? I didnt see it in custome widget after finish uploading. Don't see it in "Show all tab too"
Custom widgets are the widgets created in widget creator. Your widget will be in Show all, you can search for it.
is there on line a repository where to share custom widgets and a manual or tutorial to use creator?
(27.07.2020, 13:19)Daniel Wrote: The widget looks ok but there seems to be some issue in mosaic with adding custom widgets. I will ask developer to look at it.
Hello, I am trying to upload the file in different ways, but I haven't been able to. Could you tell me how to do it?
What are you trying to import?
(06.03.2025, 16:34)Daniel Wrote: What are you trying to import?
Hello, I am trying to upload the file Air.tar.gz, which was posted on the forum on 05.08.2020 at 08:49
.gz   Air.tar.gz (Size: 5.98 KB / Downloads: 1)
First you must unzip it as Mosaic accept now only row files script.js and style.js and as the documentation states you must use unique ID in this case it is 'gamma_air', change this name to something else. This name is used twice in script.js, change both to the same new name.
