Run query
how can I successfully run such query on LM? I don't have any visfloors yet, and I don't have also no error after executing this command but it not works.
res = db:execute([[
INSERT INTO visfloors (`id`, `building`, `layout`, `type`, `sortorder`, `name`, `background`, `background_add`, `bgcolor`, `touch_bgcolor`, `bgrepeat`, `bgfixed`, `usermode_param`, `touch_param`, `width`, `height`, `locx`, `locy`, `pincode`) VALUES
(`1`, `1`, `8`, ``, `1`, `0.00_Witaj`, ``, `0_00_Witaj.svg`, ``, ``, `0`, `0`, ``, ``, `1024`, `748`, ``, ``, ``),
(`2`, `1`, `424`, ``, `56`, `1.01_Klatka schodowa`, ``, `1_01_Klatkaschodowa.svg`, ``, ``, `1`, `0`, ``, ``, `1024`, `748`, ``, ``, ``)
-- res: nil
I know that probably I can use db:insert() but as I checked yesterday it only works for one row not many.
SOLVED: I've changed `` with "" and used integers where it is possible
Done is better than perfect
But now I have such situation:
I've imported visfloors and then visobjects (all by insert sql).
I have these floors and objects in db but only Layouts and Widgets are visible in UI. I've tried to refresh web browser and reboot LM but without any progress.
What is necessary to create in script new plan and objects?
You plan must reference an existing level (building field in visfloors table -> id field in visbuildings table).
(20.07.2020, 06:16)admin Wrote: You plan must reference an existing level (building field in visfloors table -> id field in visbuildings table).
In visbuildings I have 2 buildings:
id: 1, name: "Main",
id: 2, name: "Floors"
In visfloors I have first plan:
id: 1, building: 1, layout: 8, type: "", name: "0.00_Witaj" ...
And this plan has at least one below object:
id: 6301, floor: 1, type: 0, object: 3174, statusobject: 3174
So it should be visible in plans but I don't have it, I have only Layouts and Widgets.
And when I click on Main->Export then I have big backup including above plan with id 1.
type must be NULL not an empty string
ExactlyWink
Thank you very muchWink
