Weather info yr.no new API
service yr.no now use new API and advice use .json format for weather data reading. .xml will not supported anymore from start of the next year.
Info here: https://developer.yr.no/doc/
May be some created script based on .json and new API?
I just tried to read data for me and receive error:
link to info with .json:          https://api.met.no/weatherapi/locationfo...ltitude=13
Script I tried to read data:
require('json')
https = require('ssl.https')
escape = require('socket.url').escape
url = 'https://api.met.no/weatherapi/locationforecast/2.0/complete?lat=67.8596&lon=35.0904&altitude=13'
url = string.format(url)
res = https.request(url)
log(res)
data = json.pdecode(res)
log(data)
if type(data) ~= 'table' then
  alert('failed to load weather data')
  return
if data.error then
  log('error', data.error)
  return
I received such error:
* string: 403 Forbidden
User-Agent header LuaSocket 2.0.2 is not allowed, use a unique identifier
What is incorrect in my trying?
Alex
i tried it got the same error, looking at the documents it say "that you must send a unique identifier in the User-Agent header. Any requests with a prohibited or missing User-Agent will receive a 403 Forbidden error."
i don't know how to pass the headers with socket.url but i tried it with http.request, like the below with the User-Agent header, it returns the data
function get_request(url)
  local http, ltn12, sink, res, err
  ltn12 = require('ltn12')
  http = require('socket.http')
  sink = {}
  res, err = http.request({
      url = url,
      method = 'GET',
      headers =
      ["Accept"] = "*/*",
      ["User-Agent"] = "1234567897",  -- i think this can be any number?
    sink = ltn12.sink.table(sink)
  if sink then
    return table.concat(sink)
    return nil, err
x = get_request('https://api.met.no/weatherapi/locationforecast/2.0/complete?lat=67.8596&lon=35.0904&altitude=13')
log(x)
You can override default user agent like this. This example uses LM MAC address to create a unique number for the user agent string.
json = require('json')
mac = 0
io.readfile('/sys/class/net/eth0/address'):gsub('%x%x', function(v)
  mac = mac * 256 + tonumber(v, 16)
end)
http.USERAGENT = 'LM ' .. mac
res, err = http.request(url)
log(res, err)
Super,
thank you Admin
