localbus
hi , i am trying to work with localbus but i don't receive any logs from the groupcallback  function, i want to monitor several obj in a resident script.
in the attached i can see the handlers table but also udp{unconnected} maybe this is my problem ??
lb = require('localbus').new()
lb:sethandler('groupwrite', groupcallback)
lb:sethandler('groupread', groupcallback)
lb:sethandler('groupresponse', groupcallback)
log(lb)
function groupcallback(event)
  log(event)
  if event.dst == '0/2/1' then
    local value = knxdatatype.decode(event.datahex, dt.uint16)
    log(value)
many thanks
Hi!
Does script engine gives you any errors?
Check that on error log...
You need to call step for it to receive data. You should also define callback before setting it.
if not lb then
  lb = require('localbus').new(1)
    log(event)
      log(value)
lb:step()
(31.07.2020, 08:35)admin Wrote: You need to call step for it to receive data. You should also define callback before setting it.
if not lb then
    log(event)
      log(value)
lb:step()
Many Thanks Smile
