Threads: 3
Hi everybody,
I'm looking for a solution to separate one data int64 into two data int32, in the aim to send energy from a smartlink (int64) via bacnet (int32).
In the device wich receive the two point int32 via Bacnet, i will aggregate this two points to reach the original value.
Thanks,
Best regards
Hubert FEBRAUD
Home automation integrator
Connectibat, Nantes, France
Which device are you using? Latest LM firmware supports int64 in BACnet.
Threads: 3
(05.08.2020, 08:11)admin Wrote: Which device are you using? Latest LM firmware supports int64 in BACnet.
It's a Wiser for KNX in 2.4.0
Hubert FEBRAUD
Threads: 31
There is a fix for this, you can send the whole int64.
https://dl.openrb.com/lmup/2020.07.14-bacnet-64bit.lmup
You may need latest fw for wiser 2.5.1
Threads: 3
Thanks everybody, it works fine.
Solution : firmware 2.5.1 with patch is OK
I hope this can help someone else.
Hubert FEBRAUD
Threads: 8
Aahhh, yep your right 4x8 = still 32 (:
Sorry missed that on my free day (:
Threads: 31
Admin has a free week
Threads: 8
He deserves it!
And he is always sharper then me so that’s not an excuse (:
