Counter for a script.
Hi there
For the past two hours I've been trying to declare a variable that would count how many times the LogiMachine has not reached the Internet.
If I don't declare the variable PingFailure, I get to following error message:
Resident script:17: attempt to perform arithmetic on local 'PingFailure' (a nil value)
If I do declare it, it never counts above 1 as it resets itself each time I carry out the script.  How is this done, I've searched this forum and the Internet?
function ping(ip)
  local res = os.execute('ping -c 2 -W 5 ' .. ip)
  return res == 0
local PingFailure = 0
ping = ping('google.com')
if ping then
  log('INTERNET connected')
  log(ping)
  log('INTERNET disconnected')
  log(ping)
  PingFailure = PingFailure + 1
log(PingFailure)
I look forward to hearing from you.
Cheers!
Martin
(11.08.2020, 11:46)kropfm Wrote: Hi there
function ping(ip)
  return res == 0
if ping then
  log(ping)
  log(ping)
log(PingFailure)
Cheers!
Martin
You should use next construcion:
if not PingFailure then
  PingFailure = 0
In this situation it'll refresh only when you restart script.
You overwrite the function with ping = ping('google.com')
Try this:
if not ping then
  function ping(ip)
    return res == 0
  failcount = 0
res = ping('google.com')
if res then
  failcount = 0
  failcount = failcount + 1
log(failcount)
(11.08.2020, 12:37)admin Wrote: Thank you Erwin this solves the problem. Looks like I have to do some more reading up on LUA.
Thanks!!
Try this:
if not ping then
  function ping(ip)
    return res == 0
  failcount = 0
if res then
  failcount = 0
log(failcount)
Admin ~= Erwin so you need to thank Admin not me  Big Grin
thanks Admin. Looks like I'm still a bit challenged with the forum;-)
