Homelynk Admin Password
Hello
I have "inherited" a KNX project with a homelynk server installed.
Unfortunately, the previous integrator is no longer available for the project and the current administrator password is unknown. For the visualization part, a new setup would not be that difficult however he implemented some "magic" logic modules which also are not documentet.
Is there a way to get hold of the admin password without resetting the machine?
Would it be possible to read the current project from the e.g. SD card, reset the system and load the project again into the system?
Thanks for your help
--Thomas
It's not possible to recover the password. But it can be changed if you can access the SD card from Linux.
(12.08.2020, 14:21)admin Wrote: It's not possible to recover the password. But it can be changed if you can access the SD card from Linux.
That sounds very interesting. Yes, I can access the SD Card from Linux.
Could you give me details on how to change it?
Thank you !!
Sent via PM
Can you send me the procedure ?
B.R.
(13.08.2020, 13:39)admin Wrote: Sent via PM
Can you also send me the process?
thx
Thank you !!
Could you please send me the way to do it to?
Thank you in advance!
KR
Stefan
