Threads: 44
20.08.2020, 05:17
(This post was last modified: 20.08.2020, 06:27 by benanderson_475.)
How can i create a lua table of the last dates and days for the previous 14 day period, starting at today?
I want to end up with {day 1 = {date = "8/19/2020", day = "wednesday"}, day_two = {date = "7/19/2020", day = "Tuesday"}....... }
i started with
Code: t = os.date("*t")
data ={}
today = os.date('%w') --%w weekday (3) [0-6 = Sunday-Saturday]
Index = 1
for i = 1, 14 do
data[i] = today -Index
Index = Index+1
how can i filter out the -ve values and make it circular 0-6 to line up with the %w pattern
You need to use modulo (%) operator for this:
Code: data = {}
for i = 1, 14 do
data[ i ] = (today - i) % 7
log(data)
Threads: 44
20.08.2020, 23:12
(This post was last modified: 21.08.2020, 01:12 by benanderson_475.)
(20.08.2020, 06:46)admin Wrote: You need to use modulo (%) operator for this:
Code: data = {}
for i = 1, 14 do
log(data)
Many thanks,
how can i also get the associated date for the previous days?, taking into account if the range of 14 days is between 2 months,
i have so far the below it assumes feb has 28 days but im not sure it is correct and works properly....
also, is there a way to include the leap year so days_in_month {Feburary} is changing depending if it is 28 or 29 days?
Code: days_in_month = {31, 28, 31, 30 ,31, 30, 31, 31, 30, 31, 30, 31}
data = {}
today = os.date('%w') -- week day number
month_day = tonumber(os.date('%d') )-- date in month for day
month_num = tonumber(os.date('%m')) --%m month (09) [01-12]
for i = 1, 60 do
mth_day = (month_day - i) % days_in_month[month_num]
if mth_day < 1 then
log('exceeded month getting prev month date')
month_num = month_num-1
mth_day = days_in_month[month_num]
data[ i ] = { day_num = (today -i) %7, day_in_month = mth_day, month_date = month_num}
log(data)
Threads: 8
21.08.2020, 07:21
(This post was last modified: 21.08.2020, 10:04 by Erwin van der Zwart.)
You made it way to complicated (: Try this:
Code: time = os.time()
data = {}
for i = 1, 365 do
datetimetable = os.date('*t', time)
data[ i ] = { day_num = datetimetable.wday, week_day = os.date('%A', time), day_in_month = datetimetable.day, month_date = datetimetable.month}
time = time - 86400 -- substract 1 day
log(data)
To have a table like in your initial question try this:
data = {}
for i = 1, 14 do
data['day ' .. i] = { date = os.date('%x', time), day = os.date('%A', time)}
log(data)
Threads: 44
(21.08.2020, 07:21)Erwin van der Zwart Wrote: Hi,
data = {}
for i = 1, 365 do
log(data)
data = {}
for i = 1, 14 do
log(data)
Erwin Hi Erwin,
Yes i did make it very complicated..., your way is much better
Many Thanks
Threads: 20
20.06.2021, 11:48
(This post was last modified: 20.06.2021, 11:49 by Dré.)
Code: data = {}
for i = 1, 14 do
log(data)
please can you tell me where i can find that module to import in the LM?
