Object logs source address
When LM script send some information to group address (by grp.write command), then in object logs i can see that information (in source address i can see "local (se)"). I wondering, maybe there are method, that i can modify source address information when i sending data, so i can filter better?
For example: when resident script "test" write any data to 0/0/1 group address, then i want to see in object logs, that source address: "resident script - test" sent "data" to 0/0/1 address.
You can set grp.sender but it's limited to 2 characters. In new FW you can set grp.meta to any value before using grp.write or similar calls. It will be shown in Login / metadata column in Object Logs.
(27.08.2020, 13:25)admin Wrote: You can set grp.sender but it's limited to 2 characters. In new FW you can set grp.meta to any value before using grp.write or similar calls. It will be shown in Login / metadata column in Object Logs.
I can't find any information about grp.sender and grp.meta. Maybe you can send some examples?
grp.sender = 'ww'
grp.meta = 'something'
you have to use this before each grp.write otherwise it will go back to default.
PS. 40 telegrams/sec is too much for KNX, slow it down.
(28.08.2020, 08:58)Daniel. Wrote: you have to use this before each grp.write otherwise it will go back to default.
Thank you.
