CANx DALI gateway minimum level
I have install a CANx Dali Gateway and in the dali device parameters I can't change the minimum level lower than 182. It's write that the "Physical minimum = 182" what is this value ?
I would like to change this minimum level to 10. The graduation is not enought between 182 and 254.
There is a screenshot in attachment.
If someone can help me please.
This should be the minimum value to which you can dim using this ballast. You can't go lower than that.
(01.09.2020, 14:36)Daniel. Wrote: This should be the minimum value to which you can dim using this ballast. You can't go lower than that.
Ok thank you Daniel.
