Gefen Integration
Hello again,
I need to setup a Gefen 4x2 UHD Matrix on a installation and I like to know if someone installed it before, I read it is possible to control the Matrix via IP... I add a user manual and I try to make a scrip to control it. BR.
.pdf   GTB-HD4K2K-442.pdf (Size: 6.43 MB / Downloads: 11)
Try this to set IP config over RS232 (if needed):
-- To set up IP control, the network settings for the 4K Ultra HD 4x2 Matrix for HDMI must be configured via RS-232. -- RS232 Script to set IP control -- Load Modules require('serial') -- Open connection port = serial.open('/dev/RS232', {  baudrate = 115200,  databits = 8,  stopbits = 1,  parity = 'none',  duplex = 'full' }) -- Function to read until carier return is received or timeout function readline(port, timeout)  local char, buf  buf = {}  while true do    char = port:read(1, timeout or 0.2)    -- error (timeout) or newline, stop    if char == nil or char == '\n' then      break    -- ignore cr char    elseif char ~= '\r' then      table.insert(buf, char)    end  end  return table.concat(buf) end -- Function to write to port and return a reply function writetoport(port, timeout, command)     -- Write data to port as HEX  port:write(command)     -- Call function to read data  line = readline(port, timeout)  if #line > 0 then      return line  else    return "No reply received"  end end -- Send command to port and wait for reply or timeout reply = writetoport(port, 1, '#sipadd 192.168.2.190')-- Timeout is set to 1 second (default = 0.2) log(reply) -- Send command to port and wait for reply or timeout reply = writetoport(port, 1, '#snetmask 255.255.0.0')-- Timeout is set to 1 second (default = 0.2) log(reply) -- Send command to port and wait for reply or timeout reply = writetoport(port, 1, '#sgateway 192.168.1.5')-- Timeout is set to 1 second (default = 0.2) log(reply) -- Send command to port and wait for reply or timeout reply = writetoport(port, 1, '#set_telnet_port 23')-- Timeout is set to 1 second (default = 0.2) log(reply) -- Send command to port and wait for reply or timeout reply = writetoport(port, 1, '#set_http_port 80')-- Timeout is set to 1 second (default = 0.2) log(reply) -- Send command to port and wait for reply or timeout reply = writetoport(port, 1, '#set_udp_remote_ip 192.168.1.227')-- Timeout is set to 1 second (default = 0.2) log(reply) -- Send command to port and wait for reply or timeout reply = writetoport(port, 1, '#set_udp_port 56')-- Timeout is set to 1 second (default = 0.2) log(reply) -- Send command to port and wait for reply or timeout reply = writetoport(port, 1, '#set_udp_remote_port 50008')-- Timeout is set to 1 second (default = 0.2) log(reply) -- REBOOT MATRIX NOW
And after reboot try this to control:
-- Control over UDP -- Function Udp Send function udpsend(message,ip,port)  require('socket')  local client = socket.udp()  if client then    client:sendto(message,ip,port)    client:close()  end end result, err = udpsend('#power 0','192.168.1.227', 50008) -- Command to power on log(result) result, err = udpsend('#power 1','192.168.1.227', 50008) -- Command to power off log(result)
Not tested so i hope it works for you (;
Erwin van der Zwart
