error handling
When decoding a json string you can get different errors.
Is this code the best way to handle errors? or is there a more generic way to do this?
if states and states ~= '' then   local success, res = pcall(json.decode, states)   if success then     states = res   end end
You can use json.pdecode which will return nil, err in case of an error:
res, err = json.pdecode(data)
